Relay Issue? Gauge Cluster not Working? HELP!
Old Aug 3, 2007 | 08:10 PM
jdmeg6hatchy's Avatar
Default Relay Issue? Gauge Cluster not Working? HELP!
I have a 1992 civic hatchback I woke up this morning an the entire gauge cluster didnt work as well as the direction lights, reverse lights and the clock? Any ideas, I checked the fuses both under the dash and in the bay, none were blown. Could it be a relay? If so which one?
Old Aug 3, 2007 | 08:40 PM
Default Re: Relay Issue? Gauge Cluster not Working? HELP! (jdmeg6hatchy)
any ideas?
Old Aug 3, 2007 | 08:48 PM
gsxr1k05's Avatar
was there anything you did last night that could have jarred something lose? maybe the wire harness came unplugged somehow.. thats all i can think of.. check the back of the cluster.. also download the civic service manual.. i'll edit the post and put the link for you.
http://www.hondahookup.com/man...c.zip
Old Aug 3, 2007 | 09:21 PM
Default Re: (gsxr1k05)
thanks man.
naw, didnt alter anything. I took the cluster out, it was hooked up and plugged in fine...
Default Re: (jdmeg6hatchy)
the cluster lights up, but none of the gauges work....
Old Aug 3, 2007 | 09:24 PM
Libertariat's Avatar
Ek Forever y0!
Got a friend with a working cluster?
Try his/hers
Old Aug 3, 2007 | 10:04 PM
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Got a friend with a working cluster?
Try his/hers</TD></TR></TABLE>
haha. I tried my oem DX cluster, same problem, lights up, but the gauges dont respond
Old Aug 3, 2007 | 10:06 PM
hmtcrxsir's Avatar
maybe a wire you cut or came loose after the install?
Old Aug 3, 2007 | 10:10 PM
Default Re: (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">maybe a wire you cut or came loose after the install?</TD></TR></TABLE>
I didn't cut any wires. The JDM cluster was installed like 3 years ago.
Old Aug 3, 2007 | 10:11 PM
hmtcrxsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6hatchy &raquo;</TD></TR><TR><TD CLASS="quote">
I didn't cut any wires. The JDM cluster was installed like 3 years ago.</TD></TR></TABLE>
a wire you didnt realize you cut or kick by accident under the dash?
Old Aug 4, 2007 | 05:48 AM
just checked...nothing I could see.
Old Aug 13, 2007 | 10:35 AM
iitzchriz's Avatar
hey. did you ever find out what was wrong with your cluster!? someone recently hit my 94 honda civic ex on the driver side front. the car was not damaged badly but the steering wheel column is bent a little. the cluster was workin fine for 2 days and now the cluster does not work at all? neither does my clock. or reverse light. basically the same porblem as you.
Im new at this so i dont kno exactly how im suppose to get the reply but ill leave my email
iitzchriz@tmail.com or im @ iiitzchriz
Old Aug 20, 2007 | 09:17 AM
TheLabEG6's Avatar
Did you ever find out which fuse or relay that caused the problem. I am having the same issue and cant find the fuse responsible...
Old Jan 13, 2009 | 11:13 AM
aj_EGcivic's Avatar
back from the dead!!
having the same issue! anyone have a solution?
Old Apr 22, 2009 | 06:24 PM
Aqueous5's Avatar
Also having the exact same problem. Its gotta be something simple!
colbynorwood
Honda Civic (2001 - 2005)
Oct 30, 2012 01:55 PM
ej1gsr!
Apr 9, 2010 02:56 PM
Fo-Do Fanatic
Aug 12, 2009 09:12 PM
NazVil86
Aug 4, 2009 02:45 PM
justa4dr
Jul 30, 2008 07:17 PM
