My Reman is leaking ATF at two bolts!!! - DAM!!!!!!!
Old Aug 3, 2007 | 05:23 PM
cb900f2's Avatar
Default My Reman is leaking ATF at two bolts!!! - DAM!!!!!!!
Hey all...About 2 months and 4000km ago I had my transmission replaced under warranty on my 01 Accord LX-V6 and man the I forgot how smooth the transmission use too be!!... It was like a new car all over again! :nuts:
Well.. About two days ago, I had to get something that rolled underneath the car, and low and behold, I see from the corner of my eye some red stuff... I crawl under even further and I see ATF fluid on the bottom of the transmission housing... DAM!!!!!!!
So I clean it up as I did not know where it was coming from, and I checked the car while it was not running about 3 hours later and no ATF.. I take the car work the next day and when I get home after work, I drive the car on some ramps to get a better look, and it looks like the fluid is seeping out from two of the lower bolts that hold together the torque converter housing and the transmission/axle housing.....
I will be taking the car to the dealer to get it fixed, but what do you think on how they might attempt to fix the leak...
1/Will they loosen all of the housing bolts and re torque them all down again??
2/ remove the two offending bolts and apply some high temp sealant and reinstall the bolts???....
3/ Oh well, nothing we can do other then replace the transmission again.
I hope the link for the photo worked!
Old Aug 3, 2007 | 05:25 PM
cb900f2's Avatar
Default Re: My Reman is leaking ATF at two bolts!!! - DAM!!!!!!! (cb900f2)
Old Aug 3, 2007 | 07:13 PM
02 accord's Avatar
Picture doesn't work.
the_tensl
Jul 20, 2014 05:55 PM
SHG_Claudio
Jan 8, 2009 02:47 PM
Fuster_Cluck
Paint and Body
22
Jun 6, 2007 06:26 PM
NACvicSi
May 10, 2005 07:29 PM
Ronin Integra8
Jan 8, 2003 05:57 AM
