Compustar R/S but doesn't Crank ?
i have a 98 Honda Civic EX and just installed a Compustar CM3000, everything thing works fine execpt for the R/S. i bypass the clutch, learned tach but when i try to R/S it on reservation mode it doens't want to crank over, i can see the dash light up ready to crank but it doesn't and it keeps trying and trying until i stop it, does anybody have suggestions?
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Did you hook up the starter output to the key side or before a starter skill relay?
Sit in the car, step on clutch, activate system, if it starts you have miswired the CIS.
How exactly did you "bypass" the CIS, [clutch interlock switch]?
If it does not start, you have miswired the Compustars starter output, [yellow, CN1/6], if starter cut works, trigger alarm and engine will not turn over until you disarm the alarm, you have, as wrx-killer-Sti-eater suggests, you have wired the off board starter cut relay backwards.
94
94
really ima double check the starter kill relay but the Starter output pin 5 in CN2 i dont connect so ima try that frist and i hooked up yellow to starter side and yellow blk to key side off the starter wire, and i bypass the clutch by tappin the clutch wires together so i can start it without steppin on the clutch
The starter wire, CN2/5 red/black is not used in your car, no 2nd starter is needed.
You do not need to jump the CIS and defeat it for the remote start to work, just connect the black status output lead, CN2/2 to the output of the CIS, black/blue.
The status output will supply the ground that the starter relay needs for engine to crank, during remote start, leaving the CIS functional the rest of the time.
94
94
yesssssss, i got it, it was the starter output wire, thanks wrx-killer-Sti-eater , it was from CN2 but i still dont know y it didn't automatic lock itself after the remote start?
98civd16y8
Jun 28, 2014 06:57 AM
dirtygerman
Jun 17, 2011 07:04 PM
Bklyn TSi
Audio / Security / Video
Sep 27, 2001 07:33 PM
94
