Vtec wont pop
Old Aug 3, 2007 | 04:47 PM
BlkB16aEJ's Avatar
Default Vtec wont pop
i recently swapped out my d15b from my 95 eg, and put ina b16a 2nd gen everything went well, but eversince i started driving it i noticed the v wasnt poping i changed the p30 ecu put in a chipped p28 ecu still nothing. i let the car warm up has pleany of oil i checked the silinoid all good. I have a v tec light so it is easy to tell its been 2 weeks since i swapped it and still no vtec. i cheeked all the vtec wires all in good condition. i think it might be the oil pump but mootr only has approx 45xxx miles. in my d15b vtec poped fine im confused, semes kinda new for the pump to be going out any info is appreciated thanx
Old Aug 3, 2007 | 04:50 PM
devney's Avatar
Default Re: Vtec wont pop (BlkB16aEG)
CEL's?
Old Aug 3, 2007 | 04:54 PM
BlkB16aEJ's Avatar
Default Re: Vtec wont pop (devney)
i cheekd them and got 1 short then pause then 6 short blinks and 3 long blinks i donno wetehr or not to count the first short blink right when i turn the ignition
Old Aug 3, 2007 | 04:56 PM
devney's Avatar
im no expert with figuring out cels, but when you do post it up
Old Aug 3, 2007 | 05:57 PM
posHonda's Avatar
vtec most likely will not work if youre throwing a CEL
Old Aug 3, 2007 | 06:00 PM
hmtcrxsir's Avatar
Default Re: (iVteC_PoWeR)
i can think of five things that disengage VTEC.
1.) CEL codes
2.) Dent on oil pan
3.) Low on oil
4.) Harness not hooked up properly (check wirings)
5.) Not properly warmed up
Old Aug 3, 2007 | 06:03 PM
dohcdelsol's Avatar
Default Re: (hmtcrxsir)
**By counting the number of flashes, you can decipher the CEL #.
SHORT flashes are single digits (1/2 second)
LONG flashes are 10's (1 second)
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Old Aug 3, 2007 | 06:06 PM
envee's Avatar
your codes don't make any sense. the short is a clearing like between codes. but you either have a code 6 and a code 30 which doesn't make sense or you have a code 36 which also doesn't make sense. try again...
Old Aug 3, 2007 | 06:48 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">vtec most likely will not work if youre throwing a CEL</TD></TR></TABLE>
Not necesarily, thats a vast overstatment. VTEC will not work for CEL's having to do with VTEC itself such as oil pressure and the solonoid. Other CEL's will not affect VTEC's engagment (unless you are running limp mode)
Old Aug 3, 2007 | 06:55 PM
95jeremie's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
Not necessarily, that's a vast overstatement. VTEC will not work for CEL's having to do with VTEC itself such as oil pressure and the solenoid. Other CEL's will not affect VTEC's engagement (unless you are running limp mode)</TD></TR></TABLE>
vtec will not work if you speed sensor don't work to. just my $0.02
this is for my 95 ex....
Old Aug 3, 2007 | 07:01 PM
97Ej6mike's Avatar
Default Re: (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">
this is for my 95 ex....</TD></TR></TABLE>
Yes, speed sensor, Tach (actualy signal from dizzy), low oil, cold engine temp, if all are malfunctioning, then yes, VTEC will not work.
CEL's for other Random things will not shut off VTEC
like O2 sensors, TPS/IAC/MAP, IAT, ect.
Ive had CEL's for those in the past ( and some present), and my VTEC works quite fine
Old Aug 3, 2007 | 07:06 PM
devney's Avatar
I had a map sensor CEL and my vtec wouldn't engage
Old Aug 3, 2007 | 07:09 PM
97Ej6mike's Avatar
Default Re: (devney)
Correction, i had a clogged map sensor, not a completely deficient one. was running obesely rich , shooting clouds of black smoke upon VTEC crossover, lol.
As for your VTEC problem, have you considered taking out the solonoid itself to make sure its not clogged. Small chance that may be the case.
Old Aug 3, 2007 | 08:24 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">i cheekd them and got 1 short then pause then 6 short blinks and 3 long blinks i donno wetehr or not to count the first short blink right when i turn the ignition </TD></TR></TABLE>
That won't happen.
Video tape the CEL so somebody can tell you what it is or take it to autozone/pep boys/advance auto and get the code read.
Old Aug 3, 2007 | 08:27 PM
instrument's Avatar
97Ej6mike will be "correcting" that statement all day
knock sensor=no vtec.
Old Aug 3, 2007 | 10:45 PM
hmtcrxsir's Avatar
Default Re: (instrument)
D series has knock sensors?
Old Aug 3, 2007 | 10:49 PM
yoffer's Avatar
Banned
Yes they do.^^Only some, i cant tell you which one does have them, i know that the d16y8 has one for a fact and i believe the d16z6 has one as well.But dont quote me on this.
Old Aug 3, 2007 | 10:51 PM
hmtcrxsir's Avatar
Default Re: (yoffer)
i can tell you z6 dont have knock sensors. i think obd2 and up has knock sensor
Old Aug 3, 2007 | 10:54 PM
user 98292739's Avatar
z6 do not have knock.
Old Nov 30, 2007 | 05:27 PM
hamst3r3x's Avatar
vtec will not pop if map sensor is bad and i had and obd0 crx that had a knock sensor
BlkB16aEJ
Aug 6, 2007 12:08 AM
sho_shane
20
Mar 4, 2007 02:11 PM
MOST
11
Feb 28, 2007 01:29 AM
boosted k20
Jul 21, 2005 07:15 PM
evsproject94
Jun 6, 2005 02:01 PM
