anyone using crower cams??
im about to order some crower stage 2 cams w/stock idle lobes. anyways, they say you must use crower spring kit and retainers. that i understand. however there is a little note at the bottom that says use of this spring/retainer kit MIGHT CAUSE lifter interference due to an .060 retainer spacer that alows more spring travel. the cure for the interference is to have the bottoms of the lifters machined.
anyone had to do this? how can it 'maybe' cause interference. you would think it iether would or would not. what is the deciding factor?
if anyone knows of a better cam that will give good top end and not really sacrafice drivability, could you post a link or something. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_hondas »</TD></TR><TR><TD CLASS="quote">im about to order some crower stage 2 cams w/stock idle lobes. anyways, they say you must use crower spring kit and retainers. that i understand. however there is a little note at the bottom that says use of this spring/retainer kit MIGHT CAUSE lifter interference due to an .060 retainer spacer that alows more spring travel. the cure for the interference is to have the bottoms of the lifters machined.
if anyone knows of a better cam that will give good top end and not really sacrafice drivability, could you post a link or something. thanks </TD></TR></TABLE>
it might cause interference because there is a casting line down the rocker that could be raised on some rockers more than others. its the clearance between the retainer and the rocker you are looking at. personally, id grind it down myself with a cartridge roll because thats probably what they'll end up doing at a shop. get the clearance where you want it and thats it. its not anywhere near as complicated as it seems.
I have this exaxt setup. The retainers will end up hitting the bottom of the rocker arms with crower retainers and springs bc of the extra height. Def need to get them machined or go with a diffrent spring/retainer combo.
I just grind them on a pedestal grinder, it takes about 30 seconds a piece. IMO the offset crower retainer/spring combo is the best there is as far as retainer to valve stem seal clearance.
picture really helped. thanks everyone. any idea how much i have to grind off? i guess i'll just go untill it clears uh? im also assuming it doesnt have to look reall pretty or be scuff free.
ive posted this in other forums too and no body knows ****. glad i found the place that has members with brains
well you will kinda see it once you have the rocker in your hand, but when you are done the underside will be a smooth radius like in the pic.
as it comes stock there is a bulge of material around where the vtec pin is and that is basically all that needs ground off on the bottom.
just be sure you clean them really well afterwards as the grinding grit will get everywhere and is sometimes hard to clean up.
SiB16A
Mar 11, 2008 11:10 AM
IntegraFanatic
Apr 1, 2003 10:13 PM
HTDragazn
Nov 29, 2002 02:51 AM
