Brake Lights will not turn off....
Old Aug 3, 2007 | 12:33 PM
Jameson's Avatar
Default Brake Lights will not turn off....
I just came home last night and noticed that my brake lights stay on when the car is turned off. Someone at work told me to fix the switch but I can't find a switch. Can someone tell me what I am looking for and what am I supposed to do? Pics would also be alot of help too. Thanks!!
Old Aug 3, 2007 | 02:31 PM
pimpinblackcivic's Avatar
the switch is under the brake pedal
Old Aug 3, 2007 | 02:34 PM
Syndacate's Avatar
Default Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">the switch is under the brake pedal</TD></TR></TABLE>
x2 - it's either that brakelight switch or a short in the grounding side of the taillight harness...
Check the brakelight switch first, it's probably the problem.
Old Aug 3, 2007 | 02:44 PM
duggy's Avatar
There is a rubber peice that activates the switch so whenever you let go of the pedal, itturns the lights off. that rubber peice is gone.
Old Aug 3, 2007 | 04:00 PM
Crx Jimmy's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">There is a rubber peice that activates the switch so whenever you let go of the pedal, itturns the lights off. that rubber peice is gone.</TD></TR></TABLE>
97SS
131
Jul 23, 2021 01:30 PM
babybreese
Aug 16, 2017 12:33 PM
pythoner
May 21, 2008 11:30 AM
HondaLife2126
Apr 17, 2003 09:19 AM
