carburetor
Old Aug 3, 2007 | 10:45 AM
16v's Avatar
16v
Default carburetor
my 1.5L civic D15B7, works on carburetor i want change and set intake manifold from civic or integra, will integra's manifold fit on D15B7? must i change ECU to set injectors from other car?
Old Aug 3, 2007 | 10:52 AM
Probot's Avatar
Default Re: carburetor (16v)
how old is the engine that its carbureted ????
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 16v &raquo;</TD></TR><TR><TD CLASS="quote">my 1.5L civic D15B7, works on carburetor i want change and set intake manifold from civic or integra, will integra's manifold fit on D15B7? must i change ECU to set injectors from other car?</TD></TR></TABLE>
no, a intake manifold from a integra will not fit on your d15. swapping out the carburator is not as easy as it may seem. save your money for a swap.
Old Aug 3, 2007 | 10:53 AM
Probot's Avatar
Default Re: carburetor (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
no, a intake manifold from a integra will not fit on your d15. swapping out the carburator is not as easy as it may seem. save your money for a swap.</TD></TR></TABLE>
agreed
Old Aug 3, 2007 | 10:57 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: carburetor (Probot)
x2, save your time/money/effort for a swap.
whether that be a dohc vtec or a plain d-series.
darkclark's Avatar
if you really want to go to fuel injection you have alot of work in store. you would be best off just getting a car that a already has it. but the way to do it would be do a motor swap using all the electronics of the new motor switch to a fuel injection fuel pump because it has to make much higher pressures than the carbureted one and runnung all new fuel lines and run the new wires from the ecu to to the fuel tank. i have never done this and there might be other ways to do it but like i said it is probaby easier to just find a new car
Old Aug 3, 2007 | 11:02 PM
16v's Avatar
16v
my civic is 1993, i wonder 1.5 coupe civic has injectors why can't i set the same intake manifold on 4dr civic which works on electric carburetor.
Old Aug 3, 2007 | 11:06 PM
hmtcrxsir's Avatar
B series part onto a D series engine = Not Compatible
jman86
Dec 6, 2005 01:01 PM
Power Rev Racing
Jul 28, 2005 06:05 PM
Nikoli
Apr 10, 2005 09:21 PM
EGPHANTOM
Feb 7, 2005 09:59 AM
JM Performance
Jun 25, 2003 05:41 PM
