buzzing sound cycles on and off after startup then stops
Old Aug 3, 2007 | 10:27 AM
mosser99's Avatar
Default buzzing sound cycles on and off after startup then stops
I have a 1995 Accord EX, 117k miles.
Every time I start the engine, I hear a repeating buzzing sound coming from what I think is the ABS accumulator. It buzzes for about a second, then stops for about 5 seconds and repeats this cycle for about 2 minutes, then stops.
I'm assuming the ABS system is charging itself and when it's done, the buzzing stops.
The ABS light is not on when the car is running, but I did check the codes anyway by shorting the 2 pin connector under the glove box. I got a fast blinking light from the SRS. I think this is a 1, meaning driver's side airbag issue(?).
I also got a check engine light 17 (one long blink followed immediately by seven short blinks), which I think is VSS, vehicle speed sensor (?).
Those codes don't really help me figure out the buzzing ABS noise.
I've searched these forums and other Honda related sites but haven't found anything that tells me how I can fix this problem or at least get more info about it.
Thanks in advance for any help!
mosser99
Modified by mosser99 at 11:42 AM 8/3/2007
sparkiesteve
Oct 29, 2012 05:37 AM
russianswty
Feb 11, 2007 07:31 PM
Fliplm0de
Oct 5, 2005 05:41 AM
JDAN
Nov 17, 2004 06:08 AM
n_stemp
Sep 21, 2004 07:47 PM
