o2 sensor question
i have a 96 civic ex with an 98 ls swap the ls swap was put in the car with a dx harness and im running the ls ecu to im getting a check engine light for a o2 sensor how can i check the o2 sensor because there are two sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowej1 »</TD></TR><TR><TD CLASS="quote">i have a 96 civic ex with an 98 ls swap the ls swap was put in the car with a dx harness and im running the ls ecu to im getting a check engine light for a o2 sensor how can i check the o2 sensor because there are two sensor </TD></TR></TABLE>
your best and cheapest bet is take it to any parts store. they will run the code and tell you if it's the primary or secondary o2 sensor.
primary is the one under the header, usually before the cat.
secondary is the one after the cat.
