i need your help plz
Old Aug 3, 2007 | 06:50 AM
jdm_vtec's Avatar
Default i need your help plz
ok, everytime I turn my key over to start the car it makes a click sound and i lose all power.. nothing works, but when i turn the key back to off position my "key in ignition" alert is still beeping.. yet I get no head lights or power to the gauge cluster. the only way I can make it happen again is if I unplug the battery for a minute. What could possibly be going on here? Fuses look okay
Old Aug 3, 2007 | 06:57 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: i need your help plz (jdm_vtec)
Have you tested the battery?
Starter?
Taken a look at the main relay?
Ignition problems like this, it could be a small number of things.
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_vtec &raquo;</TD></TR><TR><TD CLASS="quote">ok, everytime I turn my key over to start the car it makes a click sound and i lose all power.. nothing works, but when i turn the key back to off position my "key in ignition" alert is still beeping.. yet I get no head lights or power to the gauge cluster. the only way I can make it happen again is if I unplug the battery for a minute. What could possibly be going on here? Fuses look okay </TD></TR></TABLE>
i would first have the battery tested.
jdm_vtec's Avatar
btw this is a stock 96 civic ex, only suspension mods at the moment
Old Aug 3, 2007 | 06:58 AM
philosofy1's Avatar
Default Re: i need your help plz (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
the main relay has to do with fuel.
Ek Forever y0!
Default Re: i need your help plz (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">the main relay has to do with fuel. </TD></TR></TABLE>
and if he's not getting fuel it wouldn't start correct? And thus the alternator wouldn't generate power.
Old Aug 3, 2007 | 06:59 AM
jdm_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Have you tested the battery?
Starter?
I know the starter has been giving me problems, but i didn't think it would kill all the power going to my accessories.. It may be the battery going dead, but then again it works after I leave it unplugged, I guess I'll check these things out further.. luckily it decided to happen while I was at home
Old Aug 3, 2007 | 07:00 AM
jdm_vtec's Avatar
and if he's not getting fuel it wouldn't start correct? And thus the alternator wouldn't generate power.</TD></TR></TABLE>
I hear the fuel pump prime when it gets power, then i turn it over and *CLICK* no power
Old Aug 3, 2007 | 07:01 AM
Ek Forever y0!
I hear the fuel pump prime when it gets power, then i turn it over and *CLICK* no power</TD></TR></TABLE>
Okay so it's not the main relay.
If the battery is weak, when you unplug it it will get back enough charge to be a little stronger.
I say swap the battery with a friend or get it tested somehow. Then get back to us.
Old Aug 3, 2007 | 07:06 AM
gtlaw1's Avatar
have you tried to jump start it or pop the clutch to get it started
Old Aug 3, 2007 | 07:39 AM
philosofy1's Avatar
? the op's problem is electrical, not fuel related. his lights don't turn on, it has nothing to do with the alternator.
have you tested the battery? if you have one, take a voltage meter and put the leads to the terminals of the battery.
it should read 12-14V. anything lower you have a bad battery. also, check your starter/battery cables. make sure none have come loose. how do the terminals look? are they corroded? clean them up a bit so they make better contact.
lets start with the easiest and the obvious here people.
JDMIntegraB16
Jan 24, 2006 09:04 PM
Groove_D
Mar 21, 2005 10:44 AM
93si
Jun 3, 2003 03:26 AM
