Sohc lsd problem......
Old Aug 3, 2007 | 06:31 AM
ennah's Avatar
Default Sohc lsd problem......
I bought a ex tranny with a welded lsd in it, i put the tranny in the car but you cannot turn the steering wheel all the way to either side and it pulls really hard to the left or right when driving........
Old Aug 3, 2007 | 06:33 AM
highrev1987's Avatar
Default Re: Sohc lsd problem...... (ennah)
start looking for another tranny, a welded diff will not last on the street
Old Aug 3, 2007 | 06:34 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Sohc lsd problem...... (highrev1987)
A welded lsd.
So it's a box type?
Sell it and get a helical type lsd. Something that's streetable.
Old Aug 3, 2007 | 09:27 AM
quicksilver1689's Avatar
i ♥ snails
hahaha that is retarded, a welded diff is essentially the same as a spool just worse in quality, its made for 1320 passes, not drving around the neighborhood and to work. Go replace it with an obx, make sure you assemble the obx to correct specs.
Old Aug 3, 2007 | 09:57 AM
ennah's Avatar
I bought it for real cheap and thought it could be streetable but i guess not, i already have another tranny layin around but why does it pull?
Old Aug 3, 2007 | 03:05 PM
fdavie's Avatar
Default Re: (ennah)
Because both wheels are always turning at the same speed. A normal ("open") differential allows the wheels to turn at different speeds so that you can turn the car. Your "closed" differential doesn't allow that, so you'll get weird skidding & pulling if you drive on a hard surface.
team 15
Jun 4, 2007 12:56 PM
UK_EG
Feb 20, 2006 08:06 AM
charjacq
Jan 5, 2003 08:42 PM
lude868
Oct 24, 2002 09:03 AM
The Punisher
Oct 11, 2001 07:42 AM
