d15b
hey guys i just did a mini me swap and i have a question.my question is the bottom block i got is a d15b jdm block w/z6 head.i notice that there is an extra sensor of some kind located right on top of the oil sensor on that d15b .its got a single wire hanging out and was curious what the sensor is or what its use for.any idea what it might be?the d15b7 and the d16z6 i got doesnt have that sensor.any help would be appreciated thanx in advance..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Hmm my d15b didnt have that.</TD></TR></TABLE>
Mine doesn't have that either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T28EG »</TD></TR><TR><TD CLASS="quote">i've been reading other threads and they mention something bout the knock sensor....could it be that?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T28EG »</TD></TR><TR><TD CLASS="quote">well its running fine i was just curious bout it....i do get a cel but havent checked the code yet......</TD></TR></TABLE>
End of story.
Take it to autozone and have it checked. Or check it yourself with the paper clip trick.
EDOT: On second though I think parts stores mostly deal in obd2
End of story.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T28EG »</TD></TR><TR><TD CLASS="quote">i do get a cel but havent check the code yet......</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T28EG »</TD></TR><TR><TD CLASS="quote">still need to check it and its an obd1</TD></TR></TABLE>
OMG, paperclip. Do you know where your ECU sits? It's under the dash, on the "kick panel" (right side wall, foot level) on the passenger's side.
Well, above it, just reach about half a handlength up, and you should be able to pull down a two wire plug that isn't plugged into anything. twist the paperclip until it makes a two pronged shape, and jam it into the plug's receptacles (don't worry, this won't hurt anything) while the car is OFF.
Then, turn the key to the number 2 position, and count the sets of long and short flashes. Long = 10, short=1, ie: _ _ -- = #22: VTEC Oil Pressure switch. Once you
have the numbers, consult the CEL thread at the top of this section for what each set of flashes means.
Now, no more questions about the mystery plug until you decipher the CEL. It might just tell you the sensor that is unplugged.
just looked at mine... i was under it anyways tightening my oil sender unit... i don't have that either
i know where its at blackout thanx....my ecu is chipped and datalogg ready so the cover is always off....like i've mention i was only curious about that sensor my ride runs well at 10 psi......that one sensor just bugg me when i open the hood thats all.....thanx
Sorry dude. I just had to assume to give directions so there'd be no need to get a return response, and then proceed from there.
Sorry, but I just don't know what that is for. I guess if it's not giving you any problems, then don't worry about it.
Clean.CL
Jun 12, 2004 02:45 PM
