Need lot's of help with MIG welding.
This is my first time welding with GAS, so please be nice...............
Am I moving to slow or not hot enough? This is the welder I am using and It will really just be used for exhaust and intercooler piping, do you know what settings are best on this?
I just don't know why they look like there sitting on the metal. I can see it penetrating but it still not flush.
Thanks for any help guy.
I would slow down your wire speed a little bit
remember mig isnt going to look perfect, but can still look good
for piping i would put the power on the 2nd lowest setting, maybe the lowest. wirefeed at like 50%
The wire speed is on 1 witch is as slow as it can go. My friend said I need to speed it up on the pipes, that is why it looks so tall.
I am also not looking for it to look like tig or anything, just want it to be a good weld.
yeah it looked like a combination of not moving fast enough, needing more heat, and too much wire speed
but of course changing one of those can affect the other, so just find the setting that works best for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">Practice on some T joint fillet welds for a while.
Like this:
nice, I'll smoke that fat joint.
by the way, just open up the cover of the welder and there should be a chart to guide you as far as the settings goes. That's the best way to start. know what gauge or thickness metal you're welding turn to that setting then go on from there.
Like this:
</TD></TR></TABLE>nice, I'll smoke that fat joint.
Thanks alot guys I will try this when I get home. I was not reading the dials and thought the top one was the heat but it was the speed. So all I was doing when I thought I was turning up the heat was making the wire faster lol.
I payed 495.00 for the welder.
Thanks I'll post some more up tomorrow.
I think you should practice with two plates and do butt welds, beveled plates and mig welds look best. Actually, practice on what you are actually going to do. Mig and thin wall pipe/tubing isn't very easy. The flat piece will not look right when you run a bead on it, there is just nowhere for the filler to go. Secondly, for flat butt welds, go forward about a quarter inch then back up into the edge of the puddle.
My welder's has been doing the same thing lately. I tried various types of setting. Could it be too thin of a mig wire? That's the only thing I chance on mine. I went from .035 to .025.
Adriano
Adriano
Is this any better?
I turned the heat up but it still a little high. Can someone show me what it should look like?
I tack welded the first pic witch seems to be a little easyer.
Thanks for the help guys.
What is your gas at?
Cleaning up the metal before welding will definitely help. But it looks like once you lay down an actual bead, you might be fine. The added heat from a constant flow should drop it down
I'll try and find some though.
