Type-R Civic B16b Pistons In GS-R
Old Aug 2, 2007 | 10:28 PM
Ra GS-R's Avatar
Default Type-R Civic B16b Pistons In GS-R
I wanna put the ctr pistons in my gsr would I have to replace the rods as well, or could i use my B18c1 rods?
Old Aug 3, 2007 | 12:16 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: Type-R Civic B16b Pistons In GS-R (Ra GS-R)
You can use the stock B18C1 rods with the B16B pistons... Unless you have an wild set of cams your motor is going to be under cammed...
Old Aug 3, 2007 | 07:41 AM
Ra GS-R's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (Project95LS-VTEC)
well i'm planning on matching up the ctr cams as well
Old Aug 3, 2007 | 09:29 AM
Byaaah!'s Avatar
Idk much about them, would you say there aggresive cams???
Old Aug 3, 2007 | 09:30 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Idk much about them, would you say there aggresive cams???</TD></TR></TABLE>
Lol, stock cams are not aggresive cams.
Old Aug 3, 2007 | 09:31 AM
Byaaah!'s Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (St Jimmy)
You know what I mean, other than LS cams...
How much diff. are they???
Old Aug 3, 2007 | 09:36 AM
dizzzane's Avatar
actually for stock cams the ctr cams are very aggressive, more so than itr cams, so it may be fine.
Old Aug 3, 2007 | 11:08 AM
saleensolution's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (JDM_dc2_B18c)
ive done this before you will prolly have to have the small end of the rod machined down a little for it ot go up into he piston
Old Aug 3, 2007 | 12:57 PM
.usdm420's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (saleensolution)
you might want to to a compression check, the CTR pistons are the most aggressive CR-wise out of all the OEM b-series pistons....you might be pushing pump gas driveability.
Old Aug 3, 2007 | 01:11 PM
Ra GS-R's Avatar
why wouldnt it be ok if they are both ctr
Old Aug 3, 2007 | 02:07 PM
your gonna be looking at about 12 to 1 compression some tuning will need to be done if your gonna run pump gas. a gsr head has a smaller quinch area than a type r does so because of that you will be running higher compression than a stock type r would
Old Aug 7, 2007 | 04:27 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_dc2_B18c &raquo;</TD></TR><TR><TD CLASS="quote">actually for stock cams the ctr cams are very aggressive, more so than itr cams, so it may be fine. </TD></TR></TABLE>
3 degrees duration more on the intake side is not aggressive
ctr pistons in a gsr is closer to 13:1
Old Aug 7, 2007 | 05:30 PM
SleeperGSR's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (doood)
so is 13:1 ok with pump gas after a tune
EDIT: is the ctr the EK9?
Old Aug 7, 2007 | 07:49 PM
ABCVTEC's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (SleeperGSR)
yes
Old Aug 10, 2007 | 03:09 PM
doood's Avatar
Default Re: Type-R Civic B16b Pistons In GS-R (ABCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">so is 13:1 ok with pump gas after a tune</TD></TR></TABLE>
it's pushing the limits of what's safe. go with 11:1 and be safer and make just as much power.
revikan
Jul 23, 2008 11:49 AM
b18c-1
Jun 14, 2006 12:55 PM
EJ8 GSR-T
Feb 20, 2006 09:42 PM
dookieK9
Feb 11, 2005 09:09 PM
B00ST2nR
Apr 17, 2002 01:26 PM
