1995 Honda Civic LX, Which wire is for the radio memory?
Everything is wired perfectly except that the stereo, doesn't hold the preset station memory. Does anyone know which wire I am suppose to splice and connect to the antenna memory wire coming out of the headunit wire harness?
NO! CUT THE GREEEEN WIRE!
lol, the yellow wire is usually the constant 12v. I'd have to look, but if you have a volt meter, test it with yellow and ground, key on and key off.
heh thanks guys... is it solid yellow or yellow with some other color on it?
Do I connect to the ant or amp REM wire or do I leave that unconnected?
Modified by xunkn0vvnx at 10:03 PM 8/2/2007
xunkn0vvnx
Audio / Security / Video
Jan 26, 2017 11:57 PM
JDMlyfestyle
19
Feb 4, 2005 07:51 PM
