A/C Compressor?
Old Aug 2, 2007 | 05:40 PM
MDM's Avatar
MDM
Default A/C Compressor?
ok so today i was driving home from work and it was traffic time and 113 degrees isnt comfortable sumtimes, so i turned on the A/C but sum loud noise came out of under the hood, so i pulled over and popped the hood and heard the noise coming from the compressor which im not sure, it might be the clutch thing but i dont know so what do u guys think??
any help appreciated!!
TIA
Old Aug 2, 2007 | 06:39 PM
MDM's Avatar
MDM
Default Re: A/C Compressor? (MDM)
anyone??
Old Aug 3, 2007 | 07:29 AM
MDM's Avatar
MDM
come on guys.. sumone should know!
Old Aug 3, 2007 | 08:49 AM
Hex420's Avatar
These questions do not get answered for some reason, no one wants to talk about A/C I guess. It's just not JDM, Ha. I had this same problem on my old Del Sol and it turned out to be the bearings in the compressor. It will still work but make a really loud squeeking noise at high RPM's. It is the compressor telling you that it needs new bearings. I have heard of people replacing them, but you have to keep the coolant becuase they do not sell it anymore. A new compresoor might be the way to go. The clutch is engaging fine if it still gets cold and works. Hope this helps
Old Aug 3, 2007 | 09:48 AM
MDM's Avatar
MDM
Default Re: A/C Compressor? (Hex420)
yea it helped but i guess i need a new compressor and why dont people like A/C??
dont they use it in Japan?
Old Aug 3, 2007 | 09:54 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hex420 &raquo;</TD></TR><TR><TD CLASS="quote">These questions do not get answered for some reason, no one wants to talk about A/C I guess. It's just not JDM, Ha. I had this same problem on my old Del Sol and it turned out to be the bearings in the compressor. It will still work but make a really loud squeeking noise at high RPM's. It is the compressor telling you that it needs new bearings. I have heard of people replacing them, but you have to keep the coolant becuase they do not sell it anymore. A new compresoor might be the way to go. The clutch is engaging fine if it still gets cold and works. Hope this helps</TD></TR></TABLE>
it has nothing to do with it being jdm. why answer if you don't have any reliable advice to give.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">yea it helped but i guess i need a new compressor and why dont people like A/C??
dont they use it in Japan? </TD></TR></TABLE>
it's not that people don't like to talk about a/c. i guess no one on here is that experience with compressors (at this time of the day anyway).
and yes they use a/c in japan.
Old Aug 3, 2007 | 10:01 AM
MDM's Avatar
MDM
Default Re: A/C Compressor? (philosofy1)
lol... i know im kidding
i just wanted sum more help but i guess no one knows
Old Aug 3, 2007 | 10:10 AM
94hatchling's Avatar
there are few places now-a-days that replace only the bearing or rebuild compressors. it is faster and more efficient just to replace the whole compressor. which means you are looking at about $500 for a new one.
Old Aug 3, 2007 | 10:12 AM
95b16hatch's Avatar
I had the same problem, I went to the junkyard and got a used one about a year ago and it still work fine. It was only 45$
Old Aug 3, 2007 | 10:13 AM
MeanGreenMachine's Avatar
Default Re: A/C Compressor? (94hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote"> it is faster and more efficient just to replace the whole compressor. which means you are looking at about $500 for a new one. </TD></TR></TABLE>
Old Aug 3, 2007 | 10:17 AM
MDM's Avatar
MDM
Default Re: A/C Compressor? (MeanGreenMachine)
damn 500.. well im swapping an ls vtec pretty soon should i wait? is anything different between sohc and dohc a/c setups???
Old Aug 3, 2007 | 10:21 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">damn 500.. well im swapping an ls vtec pretty soon should i wait? is anything different between sohc and dohc a/c setups???</TD></TR></TABLE>
yes, now you are speaking my language.
the DOHC use a larger compressor, and the lines to the compressor are ran slightly different over the SOHC.
since you plan on doing a swap, i'm taking it you have a civic. when you do the swap, you will need to pick up the compressor bracket off of a crv, and the d-series compressor and belt will bolt right up. no headaches, no custom lines. plug n play.
Old Aug 3, 2007 | 10:28 AM
MDM's Avatar
MDM
so once i do the swap i should keep the sohc compressor??
or should i just get the dohc setup??
Old Aug 3, 2007 | 10:29 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">so once i do the swap i should keep the sohc compressor??
or should i just get the dohc setup??</TD></TR></TABLE>
you won't be able to keep the DOHC set up, so keep the SOHC compressor.
Old Aug 3, 2007 | 10:35 AM
MDM's Avatar
MDM
oh i see.. but i still need a new one
so then all i need is a compressor bracket of a CRV and thats it, right??
Old Aug 3, 2007 | 10:37 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">oh i see.. but i still need a new one
so then all i need is a compressor bracket of a CRV and thats it, right??</TD></TR></TABLE>
yes, and since you have a a/c bracket from the DOHC motor, make sure you take off the pulley and pulley brakcet and put it on the new a/c bracket.
here feel free to scroll through:
https://honda-tech.com/zero...34525
Old Aug 3, 2007 | 10:42 AM
MDM's Avatar
MDM
coo thanks
Hernst
Honda CR-V & Element
Sep 22, 2015 02:22 PM
Tank_EM2
Honda Civic (2001 - 2005)
Apr 2, 2015 09:00 AM
HGZ
May 29, 2008 12:51 PM
Azn Kenny
Oct 8, 2007 01:55 PM
HONDA_TYPE_R
Acura TL, RL & ZDX
Sep 20, 2006 06:51 PM
