hf motor in civic dx
Old Aug 2, 2007 | 11:34 AM
crxricer66's Avatar
Default hf motor in civic dx
will a crx hf motor fit in a 91 civic dx?? i will be puttinng a 16v dpfi head on it. it should bolt right up right???? thx
Old Aug 2, 2007 | 11:42 AM
lilsicsoul's Avatar
Default Re: hf motor in civic dx (crxricer66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">will a crx hf motor fit in a 91 civic dx?? i will be puttinng a 16v dpfi head on it. it should bolt right up right???? thx</TD></TR></TABLE> yes ...but if i we're u just get the si motor ull be more happy...mount are all the same so deff will work...
Old Aug 2, 2007 | 11:44 AM
crxricer66's Avatar
Default Re: hf motor in civic dx (lilsicsoul)
nah im giving this to my buddy to get him around while he gets his swap going. but it will fit in right mounts are the same too?? on the hf motor
Old Aug 2, 2007 | 12:35 PM
crxricer66's Avatar
bump
Old Aug 2, 2007 | 01:25 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">nah im giving this to my buddy to get him around while he gets his swap going. but it will fit in right mounts are the same too?? on the hf motor</TD></TR></TABLE>
I don't think you can use the HF block with any other head besides the HF unless you change the pistons. Somebody correct me if I'm wrong. Also, there are other wiring changes that need to be made in order to use the HF head.
Old Aug 2, 2007 | 01:48 PM
IP RACING's Avatar
Default Re: hf motor in civic dx (wiZCo)
the dx head will bolt up. all the engines that year use same mounts. the dx si and hf motor all same mounts. but about the pistons not working Im not to sure. bump for that answer. I know the top of the pistons are diffeten because of 8 valve design and 16 valve design
Old Aug 2, 2007 | 02:11 PM
burnout8488's Avatar
HF Has EGR as well.
Old Aug 3, 2007 | 06:14 AM
crxricer66's Avatar
Default Re: (burnout8488)
bump any ideas on the pistons??
Old Aug 3, 2007 | 11:38 AM
alscrx's Avatar
Default Re: (crxricer66)
Well motors have different horsepower so i am sure compression is different, Piston size may be differnt, Why not just use the whole hf motor??
Old Aug 3, 2007 | 11:39 AM
alscrx's Avatar
Well wiring is differnt, HF is multi point. DX is dual point. Need ecu,wiring harness,complete head with manifold and all sensors!!
Hf's have 4 fuel injectors
DX's have 2 injectors
Old Aug 3, 2007 | 11:43 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 &raquo;</TD></TR><TR><TD CLASS="quote">HF Has EGR as well. </TD></TR></TABLE>
It does not have EGR. I owned a 89 HF for almost 10 years. You are probably thinking of the HX Civic. Also, the HF is an 8 valve, not 16. You cannot use any other head on an HF block because the pistons have two valve reliefs in them, not four.
Modified by Buzzbomb at 5:18 PM 8/3/2007
kslimm0714
Jun 14, 2006 09:29 AM
NismoMugen
Oct 12, 2004 09:01 PM
5litereater
Jun 24, 2004 06:01 PM
SHG_Beans
Nov 27, 2003 07:53 AM
GSRSNATCH
Apr 16, 2003 07:38 PM
