From stock O2 sensor to wideband using Hondata?
Right now i'm tuned on Hondata S200b and have the stock O2 sensor in. I'm wanting to get something like the PLX or AEM wideband but i only have the one O2 sensor bung in the downpipe. What needs to be done in order to use the wideband as a replacement for the stock? I think something in Hondata needs changed but is that something i can do with the datalogging software or does a tuner need to change something. Thanks
If your wideband supports narrowband output, you could run your setup using the narrowband output from the wideband.
If it does not, you could simply run in open loop all the time & use your 0-5volt wideband output for datalogging purposes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">If your wideband supports narrowband output, you could run your setup using the narrowband output from the wideband.
yup thats it.
yup thats it.
