please help with apexi auto turbo timer install in my EF hatch!!!!!!!!!
Old Aug 2, 2007 | 09:44 AM
superhatchbackbros's Avatar
Default please help with apexi auto turbo timer install in my EF hatch!!!!!!!!!
just as the title says. can someone please help me install this apexi auto turbo timer in my EF hatch. this is all i know so far is this correct?
1. RED- 12v* constant
2. blue-IG2 output
3.green-IG1 output
4.white-02 sensor? now do i tap in from the ecu or go right out to my 02 wiring under hood? im still obd0 1 wire 02.
5.black- ground. and said if i tap the 02 from ecu to use the ecu ground? what is best to do? own ground or ecu ground and use the 02 wire from ecu? please give good feeback thanks
6.GRAY- parking brake switch? now i dont have a parking brake switch i dont think? or is it the one that when i pull the ebrake up the light goes on the dash saying brake is on? and if it easy to find if i pull up the center console? please help bc im sure i need this safty ON...
now that i gave what i think is right. if not can someone please correct me and give me some feedback on my questions? whoever has done this in a ef befor? also pictures would help greatly and i would appreciate it.. thanks in advanced hondatech member...
* HELP me get my turbo ef project up and runing..
Old Aug 2, 2007 | 02:11 PM
none ever installed a tURBO TIMER in a EF befor?
Old Aug 2, 2007 | 03:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (superhatchbackbros)
i dont know if these are the same, but for 92-00 use this:
https://honda-tech.com/zerothread?id=1147555
Old Aug 2, 2007 | 03:19 PM
Sprockets's Avatar
Do yourself a favor and just buy the wiring harness from Lightning. I have the original silver Apexi timer, but I bought a black one that hasn't been installed yet, and the harness to make things easier (My car's a '99, so I'm not 100% sure they make it for your application). Skip the parking brake wire. Run the white and black wires to the ecu.
Old Aug 2, 2007 | 03:24 PM
Sprockets's Avatar
Default Re: (Sprockets)
This is what I'm talking about:
http://shopping.lightningmotor...t=265
Old Aug 2, 2007 | 03:28 PM
thanks everyone for the help. but sprockets if u didnt read i have a ef 88-91. i havnt seen the harness for my year , starts with 92-95 civic im going to have to solder it..
Old Aug 2, 2007 | 03:45 PM
Sprockets's Avatar
Sorry, man. I didn't pay attention to the year of your car. I'll bump this for you later if no one responds.
Old Aug 2, 2007 | 11:20 PM
is thier like a chart i can go by. ir any better pic. i seen the one pic and tahts all over the net, i was just wondering if anyone has done this and took pics? please help im going to try and atempt this tomrrow.. thanks again hondatech.
Old Aug 3, 2007 | 02:24 PM
anybody???? please help if u got anymore info..
Old Aug 4, 2007 | 04:50 PM
ok everyone i just finished puttin in the apexi auto turbo timer in my 89 ef hatch.. the wires went as following
red- solid white
blue- solid yellow
green- black.yellow
black-ground
grey- is saftey ebrake
white-o2
thanks for everyone's help.
tmiller5943
Oct 28, 2012 11:22 PM
superhatchbackbros
10
Aug 4, 2007 04:54 PM
turbotime
Nov 15, 2005 08:46 AM
bipedbear
Jun 22, 2005 01:09 PM
justinb
Jun 15, 2005 08:18 PM
