Axle Interchangeability?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">all 92-00 sohc axles are the same, i have used the same axles in a b8 trans, 2 z6 trans, 1 b7 trans and y8 trans. you need abs axles for a car with abs</TD></TR></TABLE>
You sure about that? F series SOHC axles don't work too well in D trannies
All D 92-00 D series axles are the same - I think.
.All D 92-00 D series axles are the same - I think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">All D 92-00 D series axles are the same - I think.</TD></TR></TABLE>
^^ Im pretty sure they are too. When I took out the D16y8 that was in my 95 I kept the tranny and put it on the D16z6. I didnt change the axles and everything seems to be fine 4 years down the road.
Yep, you're correct
.All D 92-00 D series axles are the same - I think.</TD></TR></TABLE>
Yep, you're correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si »</TD></TR><TR><TD CLASS="quote">Are the axles the same for all 92-00 B-series too???</TD></TR></TABLE>
No, just 32mm hydro b axles. And just 94-00 usdm. The only excepting in hydro axles are the ITR 36mm axles.
What about the elusive d17 cable trannys?
I thought the itr has bigger outer splines? Maybe that's only the jdm itr & ctr.
94-01 non Type-R axles are definitely interchangeable... I drive a del sol VTEC and order teg axles cause autozones computer doesn't know about the VTEC sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir »</TD></TR><TR><TD CLASS="quote">all D series axle works with other D series engines. I was using CRX axles in my z6. whoever says that it doesnt is an idiot</TD></TR></TABLE>
Not necessarily an idiot, just mistaken. It's not often people swap cable-equipped chassis parts with hydro-equipped chassis parts.
