Removed some alarm wiring, Now car wont start...
Old Aug 2, 2007 | 07:11 AM
JDMB20TDA's Avatar
Default Removed some alarm wiring, Now car wont start...
I purchased the car and under the hood ran some very small guage wiring, they ran to a little black box bolted to the Engine compartment than throught the firewall.
Inorder to clean up the engine bay a bit I cut these wires and deleted the little black box, Now it doesnt even want to crank over.
I never had the alarm working so I figured It wouldnt matter.
please Let me kno what I would have to do inorder to get my car running normal again.
thanks
Old Aug 2, 2007 | 07:19 AM
goota's Avatar
pictures would help
Old Aug 2, 2007 | 07:22 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Removed some alarm wiring, Now car wont start... (JDMB20TDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA &raquo;</TD></TR><TR><TD CLASS="quote">I purchased the car and under the hood ran some very small guage wiring, they ran to a little black box bolted to the Engine compartment than throught the firewall.
thanks </TD></TR></TABLE>
Follow every wire that you cut back to its origination and find out what one you cut that would change if the car cranked or not, like if you follow the wire and it goes straight to the battery thats obviously not it, just keep looking till you find something.
Old Aug 2, 2007 | 07:23 AM
Options's Avatar
All Secrets Known
It seems as if you removed the starter kill. You need to trace out your ignition circuit and find where the disconnect is.
Old Aug 2, 2007 | 07:32 AM
bcrosby51's Avatar
Default Re: Removed some alarm wiring, Now car wont start... (Options)
Pull the panel off under neath your steering wheel. I am sure you will see some wires from that alarm going to the starter wire or maybe the ignition wire. The starter wire is a thick Black wire with a white stripe. You will need to reconnect those back together.
Old Aug 2, 2007 | 08:11 AM
JDMB20TDA's Avatar
Default Re: Removed some alarm wiring, Now car wont start... (bcrosby51)
awesome Im going to go check that out right now, thanks guys.
Old Aug 2, 2007 | 08:47 AM
JDMB20TDA's Avatar
these are some pics of the alarm wiring, what should I be looking for? I see some wires for the alarm but some go to the ecu...
Old Aug 2, 2007 | 09:29 AM
bcrosby51's Avatar
That looks like the starter wire in the top pic. Is it cut anywhere from the red plug to the ignition switch? Are any wires from the ignition switch cut? I would pull all of the wires from the alarm out and trace them back to where they are hooked up.
Is the car even turning over when you turn the key? Or is it turning over but just not starting?
Old Aug 2, 2007 | 09:41 AM
JDMB20TDA's Avatar
not even turning over, are those blue wires supposed to be there. int that connector that goes into the fues block from the ignition switch, b/c the wires from igniton switch are untouched.
Old Aug 2, 2007 | 09:49 AM
St Jimmy's Avatar
* B A N N E D *
That black and white stripe thick wire in the top pic is the starter wire that you hook the starter kill up to. What happens with most starter kills is you cut the starter wire and both sides of the wire run through the alarm. When you took out all the wiring you left your starter wiring looking like this ------ GAP ------ now you just need to find both sides of the starter wire and connect them and it will start right up.
Old Aug 2, 2007 | 10:15 AM
JDMB20TDA's Avatar
Default Re: Removed some alarm wiring, Now car wont start... (St Jimmy)
they had it on the engine bay side...
and I giot it to turn over... but will it not fire up using a obd2 ECU?
its a obd1 p75 converted to vtec.
Old Aug 3, 2007 | 12:27 AM
JDMB20TDA's Avatar
ok obd2 vtec dizzy failed as well...
Old Aug 3, 2007 | 08:55 AM
JDMB20TDA's Avatar
bump
SiiRBrooklyn
Dec 28, 2017 09:50 AM
Dnguyen21
Feb 11, 2016 03:55 AM
SiLEnT_ST
Audio / Security / Video
Oct 29, 2010 02:24 AM
JLEK
May 9, 2007 10:06 AM
Synergy001
May 29, 2003 03:32 PM
