In desprete need of help!, VSA {(ABS)} ! LIGHT ALL ON
Ok so last night i droped my S with springs everything went smooth so when i get into my car i turn it on i get VSA ABS the triangle with the ! in it????? I disconnected the batt. to see if it would reset nothing. The car is an 07 lease so i really don't want to take it to honda WTF should i do i going crazy this is my brand new baby...........
i dont **** about the Vagina Stability Assist but the ABS light i think you can check the code. Since the VGA involves the ABS i think and your throttle body blah blah. It sounds like you might have hit an ABS sensor or something. Go around and make sure they are tight and you didnt molest them in a bad way.
well in the front when i removed the a arm there was this wire i think it was the abs sensor wire had a little stress on it but not much!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2000Forsale »</TD></TR><TR><TD CLASS="quote">sorry to tell you, i'm 90% sure you screw up the abs sensor, and you are going to need a new one.
i had the same issue</TD></TR></TABLE>
Thanks man
I just ordered them!
Thanks man
do u know if it ur abs/vsa works still?
the reason im asking is because we had one come in today at work with similar problem and came to find out a little bulb inside the cluster was blown and disabled vsa! yea i know pretty weird.. goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_s2k »</TD></TR><TR><TD CLASS="quote">do u know if it ur abs/vsa works still?
the reason im asking is because we had one come in today at work with similar problem and came to find out a little bulb inside the cluster was blown and disabled vsa! yea i know pretty weird.. goodluck</TD></TR></TABLE>
if the lite is on it doesnt work.
If there was stress on the sensor then he needs a new one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fish22 »</TD></TR><TR><TD CLASS="quote">how much did it cost?</TD></TR></TABLE>they are like 90 bucks with a honda discount i think.
unless they are very dirty, on my integra my ABS light kept coming up, i cleaned them up with brake cleaner and it went away.
but since you have VSA obviously 06+ i doubt that the case.
you have warranty?
you have warranty?
