ahhh! come on, a little help please?
Old Aug 2, 2007 | 05:05 AM
darkwater_ghost's Avatar
Default ahhh! come on, a little help please?
I have a 94 civic ex, my windows on both driver and passenger side windows only roll down to were there is about 3" until being all the way down. and on the passanger side window it really struggles to go up or down. so I took of the panel and hooked the switch back up and tryed seeing what was going on. when trying to roll the window up I noticed that the rails that move the window are trying to twist. If anyone has ever encounterd this problem I would apreciate the help.
Old Aug 2, 2007 | 06:27 AM
ic's Avatar
ic
Default Re: ahhh! come on, a little help please? (darkwater_ghost)
2 things off the top of my head:
the felt/rubber piece that goes in the window channel (starts inside the door, around the top and back down into the door) is what the glass actually slides on.
If this starts to deteriorate, it can make the windows go slow or get 'sticky.'
also, there are some areas of adjustment on the tracks and regulator which are bolts with oversized holes. loosen these, roll the window up and down and see if you can find a sweet spot to tighten them down that gives you smoother operation.
Old Aug 2, 2007 | 07:23 AM
Default Re: ahhh! come on, a little help please? (ic)
Thanks Ill check that out. really appreciate it.
328ifun
Honda Insight & CR-Z Hybrid
Oct 22, 2014 04:16 PM
acc0rdf22
Oct 8, 2009 12:17 PM
deerman2701
Nov 27, 2007 05:59 AM
smooz EK
11
Dec 5, 2006 12:08 PM
SlammedHatch90
Jan 31, 2003 03:49 PM
