00 CIVIC TIRE SIZE HELP!
Old Aug 1, 2007 | 10:43 PM
00civicnoob07's Avatar
Default 00 CIVIC TIRE SIZE HELP!
hello,
i'm new here and i need some help on tire size. sorry for the noob questions.
heres the thing, i'm lowering my 00 civic and i was wondering if i used 195/60/15 and lowering it with eibach sportlines (about 2 inch drop) will it rub like crazy? or is it okay? i know that the typical lowering tire profile should be 195/50/15, but i still have some tread left of my 195/60/15 so i planned to used it to the fullest before changing them. and would it be good if i used 195/55/15 the stock tire profile? or should i go for 185/55/15? any help will be greatly appreciated thank you for your time.
-bob
Old Aug 1, 2007 | 10:58 PM
Doostur's Avatar
When I lowered my 98 Civic i used 195/55/15. I lowered my car quite a bit (Right at 2 inches or more). I never had any issues with rubbing.
Old Aug 2, 2007 | 06:22 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 00 CIVIC TIRE SIZE HELP! (00civicnoob07)
Get 195/55-15 tires for your car. You can also use 205/50-15 tires if you like. Neither one should rub. You should NOT use 195/50-15, which is for older Civics.
As for the 195/60-15 tires on there now, they might rub, and they might not. Why don't you just try it? If they rub, get new tires (195/55 or 205/50). If they don't rub, go ahead and use 'em up, then get 195/55 or 205/50 when you need more.
Old Aug 2, 2007 | 07:21 PM
thanks, i'll give my 195/60/15 tires a try first den move onto 195/55/15.
Old Aug 3, 2007 | 08:27 AM
DaveSi677's Avatar
Default Re: (00civicnoob07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00civicnoob07 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i'll give my 195/60/15 tires a try first den move onto 195/55/15. </TD></TR></TABLE>
RockInTheHill
Feb 26, 2012 05:49 PM
GsR-Freak
Apr 14, 2005 04:42 AM
DelSolDon
Mar 15, 2005 02:33 PM
1stealthls
Feb 7, 2003 11:22 AM
jeddy0120
Jan 18, 2003 10:43 AM
