soch build,
Old Aug 1, 2007 | 09:38 PM
vdawg559's Avatar
Default sohc build,
okayz.. so here it is, i bought a old school si head,,, pm6 for 20 bucks, yeah i know what a deal... it was grease up, an alil bit of rush,, but den again cant beat that price, so i was thinking, i wanna build a motor, an wondering, whats the differant between head? but yeah,, ima get a soch zc block for 50 bucks, hopefully soon,, an ima put it together, do you know how much ima get frm that motor? or should i put a d15b2 bottom,, answer an opinion would b great, an here are some pics.
for some of you who thinks, wtf im doin,, welll im tryna gain experience by doin it myself,, an also, if ineed help ill just ask,, not every one perfect,,,
Modified by vdawg559 at 2:52 AM 8/3/2007
vdawg559's Avatar
tomorro, ill clean out that old gasket place, an the valve also.
Old Aug 1, 2007 | 09:40 PM
STREETWERKZ's Avatar
Default Re: soch build, (vdawg559)
have fun getting all that water out of the head.
Old Aug 1, 2007 | 09:41 PM
vdawg559's Avatar
haha, nah, i air dry it, an after that i sprayed the head with w40 ,, i think thats the right thing to do.
Old Aug 1, 2007 | 10:16 PM
bigluelok's Avatar
i dont know to much about heads but i dont think your supposed to put water inside them
Old Aug 1, 2007 | 10:27 PM
mr.speaker's Avatar
atleast use carboard man,,don't just put the engine parts on the ground like that.
and if you're doing all that,why not just take out the valve springs,seats,retainers and valves and dip the whole head? you can make your own dip using **** from walmart..
then get new valve stem seals while that stuff is apart.
also,i hope you have a workshop manual for all the tq specs and sequences.
Old Aug 2, 2007 | 06:12 PM
vdawg559's Avatar
yes i do man, my parents own a auto shop, so its no biggy
Old Aug 2, 2007 | 06:16 PM
vdawg559's Avatar
an here it is,,, i got a si manifold, complete wid the injector an throttle body,ecu, engine harness, dizzy, starter, an a eg radiator FOR ONLY $50 BUCKS, hahahahhah, forealz tho.got it off from my boi,,, anywho... i just need that bottom end zc,, witch is that dude lagging, on me,, so i might drop in a d15b2.. but dont really wanna do that tho.. here are some pics... will update soon
Old Aug 2, 2007 | 06:17 PM
vdawg559's Avatar
, i dink thats it.. ohz i and forgot,,, yeah it came wid the stock intake also.. LUCKY me
Old Aug 2, 2007 | 06:20 PM
SIred91's Avatar
Rainman
Default Re: (vdawg559)
Wow.
The street is strong in this one.
Its a wonder he can use a keyboard at all.
But good luck with your build.
Old Aug 2, 2007 | 07:04 PM
ian1006's Avatar
those radiator fins seem pretty beat up and smashed...
Old Aug 2, 2007 | 07:19 PM
vdawg559's Avatar
IT NOT SO BAD
Old Aug 2, 2007 | 09:08 PM
civic89si666's Avatar
its an sohc motor. i saw the title and figured you mistakingly spelled it wrong. but you also spelled it wrong in your posts. Also i dont think its safe to put water in a cylinder head but good luck on the build.
Old Aug 2, 2007 | 09:25 PM
njn63's Avatar
Default Re: (civic89si666)
Why would it be bad to put water in the head? Coolant flows through those passages when the motor is assembled.
You also don't have to put WD-40 in it because it's aluminum. That's used on steel to prevent rust but aluminum doesn't rust.
Old Aug 2, 2007 | 10:06 PM
bebo408's Avatar
subscribed, seeing a sohc rebuild motor gives me inspiration to redo my EW3.
Good luck on the build!
Old Aug 3, 2007 | 01:56 AM
vdawg559's Avatar
that true i spelled it wrong my bad,,, just was excited cus im doin a build, an wanted to share,, an get some tips on what i should to the motor, anywho.. the reason why i sprayed w40 is because , the place where your spark plugs goes,,, it was rusted,it was either that or water got into that area... any who. i seen my dad wash motor wid water,,, nothin wrong wid that,, an plus, i used this degreaser called purple power. lolz. does work... anywho.as of right now im trying to get a zc bottom end, illl keep searching for a week, if not ima just built the d15b2 block...
Old Aug 6, 2007 | 05:03 PM
vdawg559's Avatar
update, just got some P07 stock fuel rails,, i had to modd em, because dey didnt fit right,, here are some pics
all this stuff is goin to this baby,,,
here are some pics of the car, just in case, u guyz wanna see.
an since im heree showin the pic of the car, i might *** well show u how it look before, hella ugly, lolz
yea, i called that guy on fresnoracing.net, nikka supppose to give me the block for 50 bucks but hes hella lagging,,,, ill have update on that probly wedesday,
Old Aug 6, 2007 | 05:13 PM
b18c4g's Avatar
Spell Check anyone????
"okayz.. so here it is, i bought a old school si head,,, pm6 for 20 bucks, yeah i know what a deal... it was grease up, an alil bit of rush,, but den again cant beat that price, so i was thinking, i wanna build a motor, an wondering, whats the differant between head? but yeah,, ima get a soch zc block for 50 bucks, hopefully soon,, an ima put it together, do you know how much ima get frm that motor? or should i put a d15b2 bottom,, answer an opinion would b great, an here are some pics."
"an here it is,,, i got a si manifold, complete wid the injector an throttle body,ecu, engine harness, dizzy, starter, an a eg radiator FOR ONLY $50 BUCKS, hahahahhah, forealz tho.got it off from my boi,,, anywho... i just need that bottom end zc,, witch is that dude lagging, on me,, so i might drop in a d15b2.. but dont really wanna do that tho.. here are some pics... will update soon "
Old Aug 6, 2007 | 05:16 PM
cbp_crx's Avatar
Default Re: (b18c4g)
It's a good thing you put up pics, because I could not understand anything you just wrote. Anyway, good luck on the build.
Old Aug 6, 2007 | 05:19 PM
burnout8488's Avatar
Super pro build right here.
vdawg559's Avatar
HAHAHA, THANKS FOR THE CORRECTIONS GUYZ, BUT IM NOT WORRYIN BOUT THE SPELL CHECK,, IM JUST EXCITED, CUS IM BUILDIN A MOTOR ON MY OWN, FOR NOW, IF ANYTHING GOES WRONG ILL JUST ASK MY POPZ. BUT GOOD LOOKIN THO B18C4G
Old Aug 6, 2007 | 05:36 PM
b18c4g's Avatar
i understand, just had to say something. Good luck with the build and keep the pictures comming!
Old Aug 6, 2007 | 07:49 PM
IP RACING's Avatar
good luck with the build.
what kind of motor work are you planning on doing. just the a6 head with a zc bottom end.
Old Aug 6, 2007 | 10:44 PM
vdawg559's Avatar
yeah thats really the plan, tryna rebuild the bottom end wid stock internals, an den get some aftermarket underdive pulley, i heard it will break, so im scared to get em, for the head, i might get the vtech internals, but make it non a6 wid vtech internals, an wid after market cam shaft an pulley, an for the crx, i just sold it to day for 1500. and ima get me one for $350 si , its over heating, an i might b lucky, will have pics to show once i get the zc block, or the si crx,
Old Aug 7, 2007 | 02:35 PM
IP RACING's Avatar
I dont get what your trying to say, vtec internals but without VTEC.
honestly if your just getting a cam, cam gear and under drive pulley. I dont think you will make 170hp. like your saying you want
