car wont start and fries ecu!! help!!
so apparently my car throwing code and i try to check the cel and some how my ecu started smoking and i open it up and this thing fried
but the car still turn on after that but still throwing code so i drive it for a day and drive it to a friend house and i decided to change out the thermostat i dint really messed with it and some how i accidently unplug this wire dont know what it for but its underneath the distributor kinda pointy sticking out and a wire plug into it (sorry for the pic not really the acual pic just showing where i unplug the wire)
thats when my car wont turn on doesnt crank or spark so someone help me out please!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonsterB20Ek »</TD></TR><TR><TD CLASS="quote">hey u just called me right??? my old teggy.
look right there where i circled it in yellow did
u put the ground bak on there??
yes i dint messed with the thermostat i just unplug the pointy thing where the wire connect to it somehow it was loose its right where i circle it and the picture it not the actual pic in my car im just showing where i unplug the wire
</TD></TR></TABLE>yes i dint messed with the thermostat i just unplug the pointy thing where the wire connect to it somehow it was loose its right where i circle it and the picture it not the actual pic in my car im just showing where i unplug the wire
Well first off you need a new thermostat.
Maybe it's just the way you took the picture but it doesn't look like it's in right, the "nub" on the gasket has to go into that little "notch" on top - though if it was...just buy a new one, they're like 12 bucks. Or since it's warm u can just remove it completely for now.
As for the blown ECU - it has to be a surge of some sort.
Did you throw any CEL's? Especially 20 - that would help.
You said it started - so obviously the ECU is not completely blown. Go to PGFMI.org and find out what that capacitor does. That'll relate it to which system on your car had the surge. If it cooked ur entire ECU the car wouldn't have started, though I'm surprised it popped the ECU w/o throwing a code 20 AT LEAST.
EDIT:
Oh, nvm, didn't read that first line:
So can u check the codes now? If you already roasted one part, I wouldn't be afraid to go after the others...
You may have jumped the wrong wire, which one did you jump and what did u jump it with? Was it touching anything or just hanging out in the open (the plug end).
EDIT:
car start now i unplug the starter but im having trouble with the IAT (intake air temperature senso) it keep on burning up i replace a new one and that one is burnt too and thats what causing my car to throw a code
help!! my ecu keep on frying!! i try every chipped ecu and some how the ecu keep on smoking it burnt the same parts everytime i try diff ecus just like this one (red circle) what could it be!!??
I’m new but the same cap blew up in my car but it fried a quarter size spot on the ecu. It has to deal with fuel and other things you can check it out go listen for your fuel pump to come on when you turn the key. My car was running and it just died because of that. Some one that knows how to work a soldiering iron can fix it my buddy did mine it looks like crap but that was over a month ago.
yellowjdmcrx
Nov 20, 2005 02:07 PM
