HELP with Mini-ME!
Old Aug 1, 2007 | 08:10 PM
Joecivic94's Avatar
Default HELP with Mini-ME!
Ok I did a Mini-Me swap with my D15b7 block and i used a D15b Vtec head, and a P28 ECU. I have everything installed correctly and the Vtec is wired up correct also. My problem is that vtec doesn't kick in. I have no CEL's and car runs fine. I have done everything correctly or at least i'm pretty sure i have, but vtec is not working at all. I need to know what is wrong, i've put over $700 into this and its not working right. Any help is greatly appreciated. Thanks
Old Aug 1, 2007 | 08:27 PM
ddd4114's Avatar
Default Re: HELP with Mini-ME! (Joecivic94)
How's your oil level?
I assume you're letting the car warm up completely?
Also, how do you know it's not engaging? It won't be an obvious transition.
Old Aug 1, 2007 | 08:47 PM
Joecivic94's Avatar
Default Re: HELP with Mini-ME! (ddd4114)
my oil level on the dipstick? its reading fine.. its at half right now. the car is completely warmed up, I cannot hear it engage at all, but i have i/h/e skunk2 exhaust which is ******* loud so idk if i wouldn't hear it over that or not.. but i went to this bridge thats a 1/4 mile and tryed it out tonight, when i had my old head on i could get 80 mph on the bridge and now i can only get 75 mph so i know the vtec isnt engaging.
Old Aug 1, 2007 | 08:53 PM
Syndacate's Avatar
Check your oil pressure. Then check the VTEC oil screen.
Those are just about the only things that can make VTEC not engage but not throw a CEL.
LoL - 700 on a mini-me...damn man, you didn't plan that one too well. BTW: You would have been better off with a Z6 head.
Old Aug 1, 2007 | 09:04 PM
Joecivic94's Avatar
Default Re: HELP with Mini-ME! (Syndacate)
How do i check the oil pressure, and how should it be? I checked the screen and it looked clean.. Yeah i guess i didn't plan too well, but it also didnt help buying the wrong parts like an automatic P28 for $115, then i had to buy a 5 speed P28 for $110... i got my plug wires from honda-tech and i didnt get the ones for $44 bucks, i got the ones for $95 NGK power cables, hyper silicone..lol o well thanks for ur help ill check those things out..
Old Aug 1, 2007 | 09:17 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">BTW: You would have been better off with a Z6 head.</TD></TR></TABLE>
Why do you say?
Joecivic94: You could have converted the auto ECU to a manual, but I guess it's too late now.
The following prerequisites need to be met in order for VTEC to engage:
1) Sufficient oil pressure
2) Completely warm engine
3) Throttle poisition must be sufficient
4) Must be going over ~20mph
5) Sufficient engine speed
Since you have no CEL's, the only thing that I can see which would prevent it from engaging would be the oil pressure. Other than that, I don't know what could be keeping it from engaging.
Good luck.
Old Aug 1, 2007 | 09:22 PM
Joecivic94's Avatar
well ill check the oil pressure, and throttle position, otherwise i've done the other 3 things. Thanks man
Old Aug 1, 2007 | 09:27 PM
94c1v1cex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joecivic94 &raquo;</TD></TR><TR><TD CLASS="quote">but i went to this bridge thats a 1/4 mile and tryed it out tonight, when i had my old head on i could get 80 mph on the bridge and now i can only get 75 mph so i know the vtec isnt engaging. </TD></TR></TABLE>
what the hell are you doin tryin to go fast on a bridge?? thats not the smartest thing in the world...
Old Aug 1, 2007 | 09:31 PM
Joecivic94's Avatar
Default Re: HELP with Mini-ME! (94c1v1cex)
lol, I live in a small town in Northern Maine.... that is the only place I can go to have fun.
Old Aug 1, 2007 | 09:37 PM
ddd4114's Avatar
I ignored that detail at first, but now I have to mention it...
Drive to a track if you want to have fun. Otherwise, drive safely for your and everybody else's sake. If you expletive up once, you or somebody else could easily be dead.
It's not worth the risk.
Old Aug 1, 2007 | 09:40 PM
Joecivic94's Avatar
I understand, this is a pretty safe place and we only do it at night so we know it cars are coming.
bhigh
Jun 22, 2009 07:44 PM
mitcho
Oct 16, 2007 09:56 AM
tlieu88
Oct 3, 2005 11:28 AM
hitvtecgetloud09
39
Sep 13, 2005 03:39 PM
widebdyhatch93
Aug 28, 2005 09:17 AM
