slight idle problem
Old Aug 1, 2007 | 07:47 PM
slo6gen's Avatar
Default slight idle problem
ok, so i have a 98 ex with a d16y8 and when the motor is cold everything is fine, the car pulls like it should and idles right at 800-950 rpm... but when it heats up after about 2 hours of driving the motor seems to bog at low rpms then it picks up at 4,xxx rpms, and when im at a stop light or whatever the idle drops to like 100 rpm!!!
I cannot figure out this problem for the life of me!!! any suggetions would be great!!
and mods are: CAI
recently replaced:
spark plugs
wires
dizzy cap and rotor
Old Aug 1, 2007 | 07:48 PM
VRD^sam's Avatar
Default Re: slight idle problem (slo6gen)
i had the same problem with my y7/y8 Intake manifold. my throttle body took a **** and switched it out for a y7 after that it ran fine...
Old Aug 1, 2007 | 07:49 PM
slo6gen's Avatar
yeah, forgot to mention... new throttle body and intake manifold with new gaskets and both are oem
Modified by slo6gen at 9:10 PM 8/1/2007
Old Aug 1, 2007 | 08:10 PM
slo6gen's Avatar
anyone???
Old Aug 2, 2007 | 04:57 AM
slo6gen's Avatar
Old Aug 2, 2007 | 10:04 AM
slo6gen's Avatar
up
Old Aug 2, 2007 | 10:11 AM
quapouh's Avatar
MAP sensor could have taken a crap ... but you would throw a code then
Old Aug 2, 2007 | 10:43 AM
slo6gen's Avatar
yeah... i have no codes
Old Aug 2, 2007 | 10:50 AM
philosofy1's Avatar
Default Re: (slo6gen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo6gen &raquo;</TD></TR><TR><TD CLASS="quote">yeah... i have no codes</TD></TR></TABLE>
replace your pcv valve. when the pcv valve is clogged it will cause the engine to have low rpms during idle. not sure about bogging though.
the valve is only about $3, give or take where you live and what part store you buy it from.
Old Aug 2, 2007 | 12:55 PM
slo6gen's Avatar
where is the pcv valve located on that motor
Old Aug 2, 2007 | 01:00 PM
meangreenEG's Avatar
clean out your IACV....
Old Aug 2, 2007 | 03:31 PM
Magik123's Avatar
the pcv valve should be under the fuel rail in the intake mani .... pinch the hose to the pcv valve while its runnin if the idle smooths out replace it if u take it out and shake it it should rattle alot that means its good if not u need a new one. i had the same prob. needed to replace the pcv then adjusted idle and the prob. was gone
n8s_ej8
23
Sep 16, 2011 12:08 PM
97ej6dx
Dec 30, 2010 11:37 AM
JDM H power
Mar 21, 2009 10:15 PM
rice a roni
12
May 24, 2005 12:31 PM
civic-si-2000
Jan 9, 2005 10:13 AM
