sorry not honda related :) DEI installers??
any of you DEI installers have access to OEM wire colors for my 97 chevy tahoe? the DC2, ha i got that one done... but now i want one in the tahoe, no clue, hahah, thanks if you can help!
12volts= red + ignition harness
Starter = yellow or purple + ignition harness
Second Starter
Ignition= pink + ignition harness
Second Ignition = white + ignition harness
Third Ignition = pink/white + ignition harness
Accessory =orange + ignition harness
Second Accessory
Keysense
Power Lock= lt. blue either door boot
Power Unlock =white either door boot
Lock Motor= gray drivers door boot
Unlock Motor = tan drivers door boot
Parking Lights+ = brown headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger purple - headlight switch
Dome Supervision white - headlight switch
Trunk/Hatch Pin tied in with doors
Hood Pin
Trunk/Hatch Release black or blk/wht low in the drivers kick
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white AC ECM
Wait to start
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - at column
Second Starter
Second Accessory
Keysense
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Hood Pin
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
TwoFaced
Dec 16, 2010 05:34 PM
superhatchbackbros
Audio / Security / Video
May 17, 2009 10:51 PM
