what exhausat and turbo?
Old Aug 1, 2007 | 07:43 PM
IronShogun's Avatar
Default what exhausat and turbo?
a LS motor in an EG, what is the best fitting turbo? Does full racing have a kit for this particular hybrid? Also, what combination of exhaust parts do I need to get in order for the correct routing and length of the exhaust.
Old Aug 1, 2007 | 07:53 PM
IronShogun's Avatar
Default Re: what exhausat and turbo? (IronShogun)
someone gotta know.
IronShogun's Avatar
someone gottak now
Old Aug 1, 2007 | 07:56 PM
IronShogun's Avatar
the reason why I want to know both is cause I think im goin to get maybe a bargain exhaust before I get a turbo cause my car is haveing a lot of restriction with the small Civic pipes.
Old Aug 1, 2007 | 08:00 PM
94c1v1cex's Avatar
we can't tell you "what turbo is best" we need to know your power goals and your budget
Old Aug 1, 2007 | 08:13 PM
IronShogun's Avatar
Default Re: what exhausat and turbo? (94c1v1cex)
Oh my fault I didnt right it clearly. What I meant with best or whatever is what turbo fits (routing of pipes etc.) a LS motor inside an EG cpe.
Old Aug 1, 2007 | 08:16 PM
IronShogun's Avatar
Same question regarding the exhaust routing and all. Like would I have to get different combinations of year, make, and models of pipes in order to ahciever the proper pipe routing? If so what is the combination I would have to do.
EX.(manifold get LS header, but rest get aftermarket Civic pipes.)
95ProjectEJ1's Avatar
There are many turbos/manifolds that are designed to fit... even with a/c if you choose to keep it.
As 94c1v1cex asked... what are your goals and what is your budget? Getting the largest turbo that will hit your hp mark isn't going to help you if it takes forever to spool
Old Aug 1, 2007 | 08:17 PM
Syndacate's Avatar
You wanna give more than 10 minutes before bumping a post next time??
If you don't have AC just about anything made for a 92-00 civic would fit that setup.
Get the setup for a 99/00 Si and the manifold will bolt right up - there's not that much difference in spacing between the B16a2 and the B18B1.
Of course you're still faced with the 5th gen vs 6th gen civic issues - but they both use half rads so it doesn't matter much.
I woudln't buy a kit, and if I did, go greddy for street turbo apps.
Old Aug 1, 2007 | 08:18 PM
LastGenEK's Avatar
Next
1clnef9
Aug 7, 2010 05:32 AM
IronShogun
Aug 3, 2007 02:41 AM
TurboCRXD16
Dec 20, 2004 01:22 AM
hondaboy21
Jun 13, 2003 03:49 PM
