Antiseize on Axle splines and nut
Old Aug 1, 2007 | 04:31 PM
lude98SH's Avatar
Default Antiseize on Axle splines and nut
recently when i removed my axles they were to say the least a bitch. The passenger side came out with alittle force however the drivers side was a PITA. I actually ended up not being able to get it out and pulled the motor with it on. Then in order to get it out had to use a hammer and chisel for about 30 mins. Pry bar wasnt working. So before i put back my new axles i was thinking maybe it would be a good idea to put some antiseize on the splines that go into the diff and int shaft and also on the splines into the wheel bearing as well as the the threads of the axle nut. Is there any drawback to doing this ? I cant see why not.
Old Aug 1, 2007 | 04:56 PM
fastlude69's Avatar
i always just do the threads with antiseize
Old Aug 1, 2007 | 05:02 PM
InvaderTrax's Avatar
I had the same problem. Tried my standard impact gun, breaker bar, torch, even a 10 foot iron pipe on the breaker bar. Ended up bending the pipe and snapping my breaker bar. Then I borrowed a Matco 700 ft/lb gun, and it broke them off in 10 seconds. It's the hammering motion that helps the most, because with the pipe, we were making more than 700 ft/lb
Old Aug 1, 2007 | 08:57 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Antiseize on Axle splines and nut (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">... So before i put back my new axles i was thinking maybe it would be a good idea to put some antiseize on the splines that go into the diff and int shaft and also on the splines into the wheel bearing as well as the the threads of the axle nut. Is there any drawback to doing this ? I cant see why not. </TD></TR></TABLE>
Yeah Anti-seize is your friend
Old Aug 1, 2007 | 09:02 PM
lude98SH's Avatar
Default Re: Antiseize on Axle splines and nut (cb7-R)
ok thanks guys.
Old Aug 1, 2007 | 09:13 PM
Eddiebx's Avatar
i woiuldnt put anti seize on the splines, it should be sufficently lubricated with oil already.
but antiseize on the threads woulndt hurt
Old Aug 1, 2007 | 09:14 PM
lude98SH's Avatar
Default Re: (Eddiebx)
which splines should be lubed with oil already ?
Old Aug 2, 2007 | 04:31 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">which splines should be lubed with oil already ? </TD></TR></TABLE>
antisieze wont hurt but it wont help either.(on the inner splines) Mainly you want it for the outer splines and axel threads...
Old Aug 2, 2007 | 07:08 AM
Eddiebx's Avatar
the splines that go into the itermediate shaft, should have oil or some grease on there, i forget, i eitehr smeared some hi temp wheel bearing grease on it, or some oil. shouldnt be a big deal because that end is sealed from the elements so it wont seize up for the most part.
Old Aug 2, 2007 | 07:27 AM
577HondaPrelude's Avatar
I use high temp bearing grease (the red-line stuff) on both the splines and the threads.
spens 91 Ef
10
Jan 27, 2009 07:47 PM
Honda Crx
Oct 31, 2005 11:10 AM
Honda Crx
33
Oct 26, 2005 07:55 AM
sidious141
47
Jan 12, 2005 11:02 AM
elmalouno
Jun 2, 2003 04:29 PM
