h22 teg won't start
Old Aug 1, 2007 | 02:47 PM
DC2_ALL MOTA's Avatar
Default h22 teg won't start
Just installed a h2b into my dc2 integra, and got everything done, but won't start. I had problems getting fuel but now i got fuel, spark, and everything seems good to go. Just cranks. I'm out of ideas.
Old Aug 1, 2007 | 06:48 PM
poison's Avatar
Default Re: h22 teg won't start (DC2_ALL MOTA)
Check your timing. Make sure everything is at TDC. Do a compression check.
Make also sure your ignition timing is also correct. Firing order 1,3,4,2.
Distributor should be as follows:
3 4
1 2
Old Aug 2, 2007 | 06:10 PM
Default Re: h22 teg won't start (poison)
Timing is dead on, firing order is correct, and just did a compression check and was 210 across all cylinders. Getting good spark, and fuel. I even tried spraying some starting fluid in, and nothing at all, just wants to crank. Any ideas???
Old Aug 3, 2007 | 09:09 AM
skunked's Avatar
check your harness ground that should be bolted to the thermostat.
You may have a spark but it could be weak....
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
scotty.b16a1
Jan 2, 2013 04:54 AM
turtleman321
Mar 4, 2007 06:07 AM
FastReligion
May 25, 2006 09:18 PM
2.2L EH2
Jul 4, 2003 04:30 PM
