Ls/vtec part out. Mounts, gsr tranny, header, ecu, Tons of parts!!!!!
Old Aug 1, 2007 | 01:19 PM
ekay. jay's Avatar
Default Ls/vtec part out. Mounts, gsr tranny, header, ecu, Tons of parts!!!!!
Parting out my motor swap guys, setup consitis off:
Ls/vtec complete longblock:
11.6cp
B18a block
Pr3 pistons + new rings
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
acl main, rod, and thrust bearings
Bored .20 over + fresh hone
Shot peened rods
micropolish crank
balanced bottom end
JG built B16 head
JG port and polish
3 Angle valve job
supertech valves,springs,retainers
comitec head gasket
stock b16 cams
skunk2 adj cam gears
spoon style calve cover
ITR intake manifold/b16 TB
The longblock will come with the following:
injectors
all sensors(iat, iacv, map, tps, ect ect)
Distributor
fuel rail/fpr(stock)
ngk sprak plugs + wires
Alternator
flywheel
6 puck TCS clutch and pressure plate
$2300
I will also have for sale the following:
Gsr tranny that has 60k and has no grinds, shifts very smooth. $700
99-00 SI shift linkage + shifter. $100
RMF style header. $500
Kenji chipped p28. $140(This does have a tunned base map of my ls/vtec motor and can be purchased at a discount with the motor.)
B-series axles + half shaft. $150
Inovative 96-00 ek motor mounts. $200
B-series starter. $50
obd2-a to obd-1 conv harness. $50
This motor is still in my car, i have not pulled it out yet. I will pulling it in the next week or 2. Im just trying to line up some sales before i pull it out.
These are the only pics i have uploaded at the moment. I have pics of the complete motor buildup and all parts that went onto it.
Old Aug 2, 2007 | 05:10 AM
ekay. jay's Avatar
Default Re: Ls/vtec part out. Mounts, gsr tranny, header, ecu, Tons of parts!!!!! (ekay. jay)
Old Aug 2, 2007 | 11:24 AM
ekay. jay's Avatar
Old Aug 2, 2007 | 05:56 PM
ekay. jay's Avatar
Old Aug 2, 2007 | 06:02 PM
GSR615's Avatar
how dat ecu work for you ?
run rich ?
vtec ?
redline ?
500 for the header is that alot ?
Old Aug 3, 2007 | 04:44 AM
ekay. jay's Avatar
Default Re: Ls/vtec part out. Mounts, gsr tranny, header, ecu, Tons of parts!!!!! (GSR615)
$500 for the header is cheap, i paid $775 for it thew way it is now...
As far as the ecu, It is a Kenji chipped p28, it will not come with my basemap chip in it, that is for my ls/vtec motor and will be sold with the motor.
Old Aug 3, 2007 | 07:35 AM
b20beast978's Avatar
pm'd
Old Aug 3, 2007 | 09:19 AM
ekay. jay's Avatar
Default Re: (b20beast978)
pm'ed you back
Old Aug 3, 2007 | 12:42 PM
ekay. jay's Avatar
Old Aug 4, 2007 | 10:32 AM
ekay. jay's Avatar
Old Aug 4, 2007 | 11:00 AM
geowynniv's Avatar
are you willing to sell me the lower timing belt cover??? i need it to adjust my timing.
Old Aug 4, 2007 | 11:09 AM
ekay. jay's Avatar
Default Re: Ls/vtec part out. Mounts, gsr tranny, header, ecu, Tons of parts!!!!! (geowynniv)
no
Old Aug 4, 2007 | 11:14 AM
GSR615's Avatar
man that header clean if i had money i would get that **** in a heartbeat
Old Aug 6, 2007 | 06:26 AM
ekay. jay's Avatar
Old Aug 12, 2007 | 09:45 AM
ekay. jay's Avatar
ninezeroteg
Jan 2, 2009 07:26 AM
GSR615
Jun 17, 2008 10:30 PM
ekay. jay
Southeast (Sales)
19
Aug 30, 2007 03:29 PM
Ekay Jay
203
Oct 5, 2005 05:56 PM
