Need Some Wiring Help... (JDM ITR OWNERS)!!!
Old Aug 1, 2007 | 12:58 PM
c1_sleeper's Avatar
Default Need Some Wiring Help... (JDM ITR OWNERS)!!!
so right now im mating a 98 USDM Integra sedan rear subharness (ie. doors, gas tank, taillights, etc) to a 98 spec JDM ITR 2dr front harness (ie. headlights, underhood fuse box, underdash fuse box, etc). im almost complete but there are a few spare wires that are left from the 4dr harness... if ur wondering why im doing this it is because im doing a RHD conversion on my 4dr teg.. its easier to do this since all the wiring is out of the car, and so i dont have to spend time splicing wires for sidemarkers, fogs, clutch switch, brake switch, etc. plus i got time to kill
anyways.. the spare wires are:
<U>FROM DRIVER DOOR</U>
LT BLU: lock in (from door lock control unit to pass. door key cylinder switch)
LT GRN: unlock in (from door lock control unit to pass. door key cylinder switch)
BLK/WHT: lock in (from door lock control unit to pass. door lock switch)
BLK/RED: unlock in (from door lock control unit to pass. door lock switch)
GRN/ WHT: ???? I DONT KNOW WHERE THIS WIRE GOES TO BUT I DIDNT SEE IT IN ANY OF MY WIRING DIAGRAMS SO IF U CAN LMK WHAT ITS FOR
[<U>B]GAS TANK[/B] </U>THESE WIRES DIDNT SHOW UP ON THE 94-97 SEDAN WIRING NOR ON THE JDM ITR HARNESS.. SO CAN U GUYS TELL IF I CAN DELETE THESE OR IF I NEED TO WIRE EM TO THE ECM...
YEL/BLU: fuel tank press. sensor ( from gas tank to ECM(VCC2), spliced to TPS)
LT GRN: fuel tank press. sensor (from gas tank to ECM(PTANK))
GRN/BLK: fuel tank press. sensor (from gas tank to ECM(SG2), spliced to Air Temp. Sensor, turns into GRN/BLU at ECM)
IM GUESSING THESE WIRES ARE FOR THE FOLLOWING.. LOCATED IN THE GAS TANK
BLK/YEL: evap emissions bypass solenoid valve (from gas tank to underdash fuse)
BLU: evap emissions bypass solenoid valve (from gas tank to ECM(2WBS)
I ALSO HAVE AN EXTRA WIRE THAT RUNS FROM THE SEATBELT INDICATOR RED/BLU WHICH IS SUPPOSED TO GO IN THE INTEGARTED CONTOL UNIT LOCATED ON THE UNDERDASH FUSE BOX. MY QUESTION IS IF THERE IS A BEEPING INDICATING U TO BUT UR SEATBELT ON WHEN U START UR CAR (FOR JDM ITR OWNERS)
ALSO I NEED A WIRING DIAGRAM FOR POWER WINDOWS, DOOR LOCKS, POWER MIRROS FOR A JDM ITR AND ALSO FOR THE INTEGRATED CONTROL UNIT LOCATED ON THE UNDERDASH FUSE BOX
THANKS IN ADVANCE FOR ALL UR HELP.. I KNOW IT LOOKS KINDA CONFUSING BUT ASK ME ANY QUESTIONS U MAY HAVE THAT WILL HELP ME FIND MY ANSWERS..THANKS
billywandell
Jun 9, 2019 08:23 PM
55superbeetle
Audio / Security / Video
Jan 4, 2010 07:42 PM
AutoXer
Dec 20, 2009 09:24 AM
crxstylin
May 19, 2008 01:03 AM
veggiemaster
Jun 9, 2005 10:13 AM
