Battery keeps loosing charge (this is my fourth battery)!!!!!
Old Jun 11, 2002 | 06:16 AM
BlowOff's Avatar
New User
Default Battery keeps loosing charge (this is my fourth battery)!!!!!
My friggin battery keeps loosing charge. It has been happening for a year now and I still can't find the problem!! My engine and battery grounds are good, the volts while running are about 14V...good. I just can't figure it out!!! Could it be a bad ground within the alternator??? What would cause the battery to drain?????
Old Jun 11, 2002 | 06:30 AM
96_GSR's Avatar
Default Re: Battery keeps loosing charge (this is my fourth battery)!!!!! (BlowOff)
Get the alternator checked..You need to make sure it is producing the correct voltage.
Old Jun 11, 2002 | 06:34 AM
brwnrice's Avatar
Default Re: Battery keeps loosing charge (96_GSR)
yes, get your alternator checked. sounds like you have a faulty alternator
Old Jun 11, 2002 | 07:39 AM
DR. ON POINT's Avatar
Banned
Default Re: Battery keeps loosing charge (brwnrice)
alternator dippy
Old Jun 11, 2002 | 08:05 AM
dVs.'s Avatar
New User
Default Re: Battery keeps loosing charge (EVIL Teken)
I encountered a similar problem.
http://www.stretcher.com/stories/960819c.cfm
http://autos.yahoo.com/repair/results/ques028.html
After doing exactly what each link said to do (which is what Teken is saying also) and the results were a little under 25 milliamps. The voltage was correct also. So basically what i'm saying is try this first if it doesn't work (like it didn't for me) e-mail me if you do find a solution (as I will do the same) because it's been bothering me for about a yr now too. The car i'm referring to is my gf's 96 civic ex coupe.
[Modified by joodontknow, 9:07 AM 6/11/2002]
Old Jun 11, 2002 | 08:18 AM
Y2K Si FBP's Avatar
Default Re: Battery keeps loosing charge (joodontknow)
i have a obd2 alternator off a 00 civic si to sell...damn you are obd1 94...oh well...
Old Jun 11, 2002 | 08:26 AM
B00STeD's Avatar
definately alternator!
Old Jun 11, 2002 | 04:45 PM
SIK IN DA HED's Avatar
New User
Default Re: Battery keeps loosing charge (b00stedb18c1)
like they all say... ALTERNATOR!
Old Jun 11, 2002 | 06:59 PM
Madness's Avatar
alternator may produce good voltage
if the diodes inside are no good may still be your problem
Old Jun 11, 2002 | 07:08 PM
Mase's Avatar
Default Re: Battery keeps loosing charge (dante_420)
damn i must be lucky, my car will be 4 years old in august and havent had the battery replaced once, and i have a 300 watt rms amp runnin.....
ALLDAY-24
18
May 3, 2011 08:25 AM
97_hatch
May 20, 2008 03:26 PM
Syndacate
Aug 14, 2007 05:10 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
Riceburner247
Oct 12, 2005 07:04 PM
