Look what i pulled out of my motor!! and it ran. back together WARNING SOHC INSIDE.
Old Aug 1, 2007 | 06:11 AM
Usdmowns's Avatar
Default Look what i pulled out of my motor!! and it ran. back together WARNING SOHC INSIDE.
Found this when I went to change my valve seals,head gasket, head studs.
But luckly Im a d-series guy and have 4 other motors laying around. So the rod was switched.
heres the motor after a light p and p.
the motor.
d16a6
.20 over
stock c/r
arp head studs
y8 head gasket
z6 i/m
port matched exhaust and intake.
b16 t/b
heres a few pics.
motors together and running good. burning mass oil need to do a compresion check. some retard rebuilt the motor before me and messed mass **** up. (colt your a dumbass)
but the motor runs good and pulls like a b16. BUT THE OIL BURNAGE IS ******* ANNOYING!!!!> Ill get more pictures in a few.
Old Aug 1, 2007 | 07:16 AM
JustAnotherRex's Avatar
If the rod was that ugly, rings?
Sure the crank is still A-ok?
Old Aug 1, 2007 | 07:19 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
Sure the crank is still A-ok?</TD></TR></TABLE>
This is my thought as well. Rods shouldn't just bend on their own.
Old Aug 1, 2007 | 08:00 AM
SIred91's Avatar
Rainman
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
This is my thought as well. Rods shouldn't just bend on their own.</TD></TR></TABLE>
they do if some idiot sucks water.... i see it all the time.
Old Aug 1, 2007 | 08:22 AM
ewaugh's Avatar
Default Re: (SIred91)
FYI, IIRC Penzoil is parafin (wax) based. I wouldn't use it in a motor that is going to run very high temps.
Old Aug 1, 2007 | 09:55 AM
Usdmowns's Avatar
^ ive noticed that...
no when i bought the motor it was boosted on. but ran fine. so it makes me wonder.
Old Aug 1, 2007 | 10:22 AM
EL Vap133's Avatar
Default Re: Look what i pulled out of my motor!! and it ran. back together WARNING SOHC INSIDE. (WideBody96)
Wow! I used to know a guy who always claimed to have been running on 3 cylinders!
Old Aug 1, 2007 | 06:15 PM
Wes V's Avatar
Default Re: Look what i pulled out of my motor!! and it ran. back together WARNING SOHC INSIDE. (EL Vap133)
<U>That's intentional!</U>
Your car has the rare factory "automatic compression lowering" feature. If the engine feels that you are having too much fun, it bends the rod and thus lowers how high the piston goes in the bore. This limits performance and as a result, how much fun you are having.
If you were having "way too much fun", all four rods would have been bent.
This feature wasn't installed in too many cars due to the factory not being able to figure out how to get the rod straight once you have gotten bored.
Wes Vann
hondaEg_808
Nov 6, 2008 07:25 PM
tunedbylorange.com
Aug 19, 2005 01:02 PM
90DXZC
Jun 8, 2005 07:25 AM
