Info on how to install adjustable fuel pressure regulator on 2000 civic ex
Old Jul 31, 2007 | 10:36 PM
si_motor_spt's Avatar
Default Info on how to install adjustable fuel pressure regulator on 2000 civic ex
Does any one have an idea, maybe a instructional guide? i have a vision motorsport adjustable fuel pressure regulator. Any help would be appreciated...
Old Jul 31, 2007 | 10:40 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: Info on how to install adjustable fuel pressure regulator on 2000 civic ex (si_motor_spt)
take off the bolts and lines on the oem fuel rail then replace.
Old Aug 1, 2007 | 11:16 PM
Default Re: Info on how to install adjustable fuel pressure regulator on 2000 civic ex (5_Lug_B)
it says that i reuse my stock regulator, its supposed to go over it, do u no any thing about that?
Old Aug 1, 2007 | 11:20 PM
n1_egsex's Avatar
* B A N N E D *
you have to cut your stock regulator in half pretty much and throw away the top portion
Old Aug 5, 2007 | 12:19 PM
Default Re: Info on how to install adjustable fuel pressure regulator on 2000 civic ex (JJSpecTuning)
Here's a link from where i got the regulator from and shows you a pic of it,
http://cgi.ebay.com/ebaymotors...h=017
Old Aug 12, 2007 | 09:32 AM
Okay peoples, heres a better picture of the rgulator...can anyone still show me how to ionstall this?
Old Aug 12, 2007 | 09:37 AM
Archidictus's Avatar
Unceasing Measure
You have to cut the stock FPR in half just above the ridge and then you use the supplied hardware to install the tophat. You can probably get exact instructions from B&M's website since their pressure regulator works the same way.
My question is why are you installing this at all?
Old Aug 12, 2007 | 11:00 AM
vtecftw's Avatar
^ im going to assume bling factor
Old Aug 12, 2007 | 12:42 PM
Default Re: (Archidictus)
well actually my air/fuel ratio gauge has been showing me super rich conditions(the rich part of the gauge is all the way to the max) and my car runs like ****, but theirs no check engine light either, i changed my stock FPR but still no luck, some members say that i should get something like this to help wit my fuel pressure, Is that really true? i havent got to drive my car on the highway for a bout 2 months already...
Old Aug 12, 2007 | 12:56 PM
Padawan's Avatar
Darth ModerVader
Default Re: (si_motor_spt)
You shouldn't need an adjustable FPR to allow a relatively stock engine to run properly. What is your current setup?
Old Aug 12, 2007 | 01:03 PM
Default Re: (Padawan)
intake,headers,exaust,pulleys,msdignition(wires,pl ugs,cap,rotor,coil)dats basically it. im just at a lost cause and dont know wat to do........
Old Aug 12, 2007 | 01:14 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_motor_spt &raquo;</TD></TR><TR><TD CLASS="quote">intake,headers,exaust,pulleys,msdign ition(wires,plugs,cap,rotor,coil)dats basically it. im just at a lost cause and dont know wat to do........ </TD></TR></TABLE>
You're wasting your time with a FPR on a stock car. Pulleys and MSD ignition wont do any good for you either.
02 Civic SI 865
Dec 20, 2006 02:19 PM
Cuong-nutz
May 5, 2005 03:43 PM
burningwrek
28
Oct 16, 2004 01:00 PM
89JDMcrx
Oct 1, 2002 07:23 AM
