stock ls crank good for high boost?
Old Jul 31, 2007 | 10:23 PM
lunatics209's Avatar
Default stock ls crank good for high boost?
ok. here's my setup. im going with a garrett gt42r. sleeved block and p&p head. going with ls-vtec motor. is the stock ls crank going to be good for high boost? looking at 35-40 psi. also what are good piston compression? 8:5 or 9:1? thanks for any input.
Old Jul 31, 2007 | 10:26 PM
BoostedEG6's Avatar
Default Re: stock ls crank good for high boost? (lunatics209)
stock cranks seem to hold up ALOT better than aftermarket ones. I think just about everyone with high HP cars are running stock cranks. So to answer your questions. Yes a stock crank will be fine
Old Jul 31, 2007 | 10:28 PM
Default Re: stock ls crank good for high boost? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">stock cranks seem to hold up ALOT better than aftermarket ones. I think just about everyone with high HP cars are running stock cranks. So to answer your questions. Yes a stock crank will be fine</TD></TR></TABLE>
ok great with that said then no problem.
aggressivecivic
Apr 7, 2008 04:53 PM
civiconfire
Oct 31, 2007 12:44 PM
EKB18BPR3
May 25, 2004 06:25 PM
just a honda
Apr 19, 2004 12:29 AM
LSiTurbo
Jun 11, 2003 05:27 AM
