stock ls crank good for high boost?
ok. here's my setup. im going with a garrett gt42r. sleeved block and p&p head. going with ls-vtec motor. is the stock ls crank going to be good for high boost? looking at 35-40 psi. also what are good piston compression? 8:5 or 9:1? thanks for any input.
Re: stock ls crank good for high boost? (lunatics209)
stock cranks seem to hold up ALOT better than aftermarket ones. I think just about everyone with high HP cars are running stock cranks. So to answer your questions. Yes a stock crank will be fine
Re: stock ls crank good for high boost? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">stock cranks seem to hold up ALOT better than aftermarket ones. I think just about everyone with high HP cars are running stock cranks. So to answer your questions. Yes a stock crank will be fine</TD></TR></TABLE>
ok great with that said then no problem.
