oil burning, valve adjustment, compression test
Old Jul 31, 2007 | 10:15 PM
climb_on's Avatar
thanks for all the help guys decided to get some proffesional help
got some good news from the mechanic!
thanks
again
Modified by climb_on at 3:49 PM 8/5/2007
Modified by climb_on at 3:51 PM 8/5/2007
Old Jul 31, 2007 | 10:21 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: oil burning, valve adjustment, compression test (climb_on)
with those numbers i would definetly think you need to get your bottom end rebuilt, your valve adjustment wouldnt throw off the one cylinder that bad unless you had no idea what you were doing, and even then it wouldnt lead to burning oil, take a cap full of oil and drop it down in that same cylinder and do a before and after compression check in that cyl
if you do compression and its low, then put in oil and it shoots up its your rings, if you put in oil and it doesnt go up its your valves
Old Jul 31, 2007 | 10:25 PM
climb_on's Avatar
Default Re: oil burning, valve adjustment, compression test (coptzer)
i think that if im burning oil then it has to be my rings
but with those number altough they differ 180 is suppose to still be pretty good compression....
Old Jul 31, 2007 | 10:28 PM
180 is good if they were all 180, but 180 is bad when compared to the 230 for the other cylinders
its like a 30 percent difference which means its definetly in need of a rebuild, sorry to be the bearer of bad news, i recall factory specs say within 10-15% acceptable
Old Aug 1, 2007 | 08:14 AM
climb_on's Avatar
well when i bought the car not too long ago the was just freshly rebuilt so i dont think its that unless i screwed it up breaking it in.
as far as rebuilding your talking about getting new rings?
so doing a wet compression test will tell me if the rings are bad?
man and i hate bad news
how much you think im looking at to get this fixed
Old Aug 1, 2007 | 08:58 AM
93dagsr's Avatar
to rebuild my gsr complete head and bottom end was around 1800
Old Aug 1, 2007 | 09:38 AM
Default Re: (93dagsr)
new rings are around 50 dollars (hasting rings at autozone) and a fresh hone shouldnt be more then 100 dollars plus labor unless you do all the work
Old Aug 4, 2007 | 02:38 PM
climb_on's Avatar
Default Re: (coptzer)
pics added, also if leaking is coming from bad valve seals would that through of my compression or is compression through off by valve seating?
Old Aug 4, 2007 | 02:43 PM
Default Re: (climb_on)
compression check only checks for valve seats and rings
Old Aug 4, 2007 | 02:46 PM
climb_on's Avatar
thanks, i tried searching for that but i guess im the only dumbass who asked that before, but i does make sense.
im going in for a leak down test monday morning to find out for sure.
and i think im going to fix the problem my self....
by a heims manual and go to work....
Old Aug 4, 2007 | 07:14 PM
standbackimapro's Avatar
Oil burning can also be caused from leaking from valve seals
Sketch_hs
Mar 28, 2006 11:13 PM
Jet Black
12
Jun 8, 2004 08:05 PM
Bbasso
Sep 17, 2003 03:22 PM
AMChev
Sep 15, 2002 10:26 AM
