H2B eg w. Cable Trans..Need to disable the VSS.
Old Jul 31, 2007 | 10:13 PM
PnkRokCountryboy's Avatar
Default H2B eg w. Cable Trans..Need to disable the VSS.
I put a cable trans in to my eg
H2B conversion.
Im getting the code for the VSS, becuase there is no VSS on that style of a transmission..duh. lol
My concern is that vtec will not engage with this CEL on even after disable the vtec speed check on crome.
I need to know if theres a conversion i can do to make everything work correctly, or if for now i can disable a VSS check.
Thanks guys, appreciate your help.
Old Aug 1, 2007 | 12:03 AM
Mista Bone's Avatar
D Tranny Guru
install a VSS and be done, yank out the cable drive unit, install your old EG VSS.
The bad news, sometimes the cable drive unit had to be pounded out from the inside.
Old Aug 1, 2007 | 08:45 AM
Default Re: (Mista Bone)
haha i never heard of that..hopefully it works..thanks
any other advice?
Old Aug 1, 2007 | 08:46 AM
Bense's Avatar
nope, what bone said pretty much sums it up
edit: use vice grips to yank the old vss out
Old Aug 1, 2007 | 11:07 AM
Mista Bone's Avatar
D Tranny Guru
just don't rip the neck off........
Old Aug 1, 2007 | 01:54 PM
lol ok.. any other advice/ just picked up a new VSS today
Old Aug 2, 2007 | 12:44 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (PnkRokCountryboy)
sink it in the hole?
You need a Buckeye to show you a Hoosier hole?
Old Aug 2, 2007 | 08:17 AM
sleepencivic's Avatar
i did the same on my y1 cable tranny in my eg hatch just used the one off my d series
Old Aug 2, 2007 | 12:02 PM
Default Re: (sleepencivic)
another successful honda tech help.. HAI FIVE!
dumpedhard
K Series
Aug 20, 2009 11:40 AM
ProjectRustyEF
Jun 25, 2008 09:58 PM
FastAsleep
Jan 12, 2007 03:47 PM
