boosted b18b (noob question)
Old Jul 31, 2007 | 09:57 PM
-[Lucky]-'s Avatar
Default boosted b18b (noob question)
Hey, if you have a 96-00 civic sedan, with a b18b, will a bolt on turbo kit fit right in or will you have to modify the tubing?
Old Aug 1, 2007 | 12:17 AM
94jdmeg6civic's Avatar
mod well be needed
Old Aug 1, 2007 | 01:35 AM
siblue_gzer's Avatar
minimal modding of pipe will be required.
Old Aug 1, 2007 | 01:34 PM
-[Lucky]-'s Avatar
Default Re: boosted b18b (JDMexican)
Thanks, and if you want to build up the head for more boost, what will you need???
Modified by JDMexican at 3:37 PM 8/1/2007
Old Aug 1, 2007 | 02:38 PM
-[Lucky]-'s Avatar
bump...
Old Aug 1, 2007 | 02:39 PM
95ProjectEJ1's Avatar
How much whp are you trying to hit?
If its under 350whp I would just send the head out for a valve job, valves, springs, and retainers. A P&P is not necessary.
Old Aug 1, 2007 | 02:43 PM
-[Lucky]-'s Avatar
Default Re: boosted b18b (95ProjectEJ1)
Im trynna hit around 300hp
Old Aug 1, 2007 | 02:44 PM
MDM's Avatar
MDM
just mess with the head meanwhile then go down to the block!!
Old Aug 1, 2007 | 03:39 PM
-[Lucky]-'s Avatar
Default Re: boosted b18b (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">just mess with the head meanwhile then go down to the block!! </TD></TR></TABLE>
But dont you need a stronger head for more boost?
Old Aug 1, 2007 | 03:43 PM
MDM's Avatar
MDM
thats what i said MESS WITH THE HEAD..
but u dont need anything for boost as long as u get a good tune at the right psi ur good to go!
Old Aug 1, 2007 | 04:05 PM
-[Lucky]-'s Avatar
Would it be good to boost a the stock engine in a 2000 civic LX?(daily driver)
Old Aug 1, 2007 | 07:19 PM
-[Lucky]-'s Avatar
yes, no, maybe?
Old Aug 1, 2007 | 07:22 PM
nix94delsol's Avatar
maybe u shouldnt turbo it for a while, u do realize ur gunna need some kinda new feul management too rite?
Old Aug 1, 2007 | 07:25 PM
-[Lucky]-'s Avatar
Default Re: (nix94delsol)
Whats the most hp i can get out of the stock 00 civic LX (sedan).
Old Aug 1, 2007 | 07:31 PM
you have the d16y7 SOHC non vtec, theres no power without boost, your better off swapping to a DOHC or buying a different car, unless u read up alot on boost
Old Aug 1, 2007 | 08:32 PM
-[Lucky]-'s Avatar
its gonna be my D.D though
Old Aug 1, 2007 | 09:45 PM
smileycvc's Avatar
Default Re: (JDMexican)
I thought you said you had a b18?
Old Aug 1, 2007 | 09:56 PM
dawssvt's Avatar
It will need to be modded.
Old Aug 1, 2007 | 10:11 PM
hmtcrxsir's Avatar
Default Re: (dawssvt)
since you stated that its a bolt on kit. im thinking that it should pipings should just bolt on too unless its a Home Made turbo where you gather the parts yourself?
Old Aug 2, 2007 | 04:32 PM
-[Lucky]-'s Avatar
Default Re: (hmtcrxsir)
Would it be better to get a b16a and boost it?
Old Aug 2, 2007 | 04:36 PM
Man... you jump around a lot. First its the B18b1, then its the D16y7, and now on to the B16?
First, choose which motor you are able to afford and would like to boost... then start another thread if you need.
Old Aug 2, 2007 | 04:40 PM
-[Lucky]-'s Avatar
OK, well which one is better for boost, and easiest to swap into a 00' LX sedan?
Old Aug 2, 2007 | 04:41 PM
ekBlackHatch's Avatar
Default Re: (95ProjectEJ1)
N/A is best
Old Aug 2, 2007 | 05:07 PM
out of the 3 you have listed... the B18b1.
Old Aug 2, 2007 | 06:04 PM
-[Lucky]-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">out of the 3 you have listed... the B18b1. </TD></TR></TABLE>
Thats the LS right? How do you get a LS/VTEC??
