new clutch required in dx and hf swaps?
i heard this and wanted to find out if it's true or not. i ehard that if you swap anything more powerful into a dx or hf (4gen), you need to upgrade the clutch to at least an si because you need the extra grip. true?
[Modified by serious, 10:38 AM 6/11/2002]
Well it obviously depends on what you are swapping in. If you are going with B series then of course you would have to get a b series tranny too. For D series, i would recommend upgrading the clutch if you don't already have an Si tranny, we are talking 4th gen right?
I am swapping a 94 Sohc VTEC (d16z6) into my 89 LX (DX, HF, same engine), i went with a 93 Clutch, pressure p, flywheel setup. If you are going to upgrade your clutch with a stock Si one, try to get a 90+ clutch, pp, flywheel because it has more splines=more grabbing surface. hope this helps.
SFlCrx
21
Oct 29, 2006 10:19 PM
mr_hahn73
Nov 11, 2005 05:58 PM
