5th Generation Mileage??
Old Jul 31, 2007 | 09:24 PM
Hyard24's Avatar
Default 5th Generation Mileage??
Ok so I want to know about how long to expect my 97' to last. Just curious as to who has the most mileage on their own 5th gen. Accord.
Old Jul 31, 2007 | 09:31 PM
5G_Vtec's Avatar
Default Re: 5th Generation Mileage?? (Hyard24)
My 95 Accord has 172,XXX miles on it and it's still running pretty strong. Just needs some minor work done to it. But, Hondas are said to last long.
Old Jul 31, 2007 | 10:12 PM
professorman's Avatar
Default Re: 5th Generation Mileage?? (5G_Vtec)
I'm currently at 155k, and I am hoping to make it to 250k without issues
Old Aug 1, 2007 | 02:01 AM
YeuEmMaiMai's Avatar
i sold my salvage 94 accord to my friend for $500 with 150K on it this year...... it was salvaged at 60K I drove it for 90K and all I had to do was
1. replace rad cap
2. repalce exhaust
3. replace driver side outer CV joint
4. recharge A/C 2X
5. brakes
6. timimg belt
Total cost for me was under $900 for 4 years and 90K miles. My friend has not had to do anything to the car yet and it is at 160K now...
Old Aug 1, 2007 | 04:00 AM
hb_guy's Avatar
Default Re: 5th Generation Mileage?? (YeuEmMaiMai)
i have a 95 accord ex with 136,xxx. and i bought it last july with 100,2xx miles on it. i drive alot
Old Aug 1, 2007 | 04:14 AM
97AccordProject's Avatar
My 97 LX has 154K on it or so... I bought in Fall 2005 with 120,385 on it.
Doing the math on it, it's like I've put 50 miles on it a day since I bought it. But I take the thing on road trips all the time.
Old Aug 1, 2007 | 06:11 AM
hondaccord's Avatar
Default Re: (97AccordProject)
my 97 has 203xxx on it and it still runs fine. the only internal work was a port and polish on the head at about 115xxx. I did have to rebuild the trans because of a leak on the slave cylinder that was never taken care of which in turn destroyed the syncros. this car has been put threw the paces for sure, but I make sure to do all my general maintenance.
Old Aug 1, 2007 | 07:44 AM
redbull-1's Avatar
My 95 EX has over 258,000 miles on it. I bought it new. Minor things did need replacement with mileage and wear, radiator, speedometer circuit board, one window regulator, power door lock actuators. The car still runs strong; but, I'm tired of it now and plan on a new car this or next year. My 95 probably will last even way longer; but, I may or may not keep it.
How long it last, depends greatly on proper maintenance.
Old Aug 1, 2007 | 08:22 AM
awdgsx96's Avatar
Mine is a 94 and had 130k when the speedo stopped working 3-5 years ago. I just fixed it about a month ago, I'm estimating about 175-180k.
It also didn't have an oil change in about 1.5 years, I just did that last week lol. Still running original belts, they will be replaced when I'm legal to drive and can get it to a shop.
I'm pretty sure these F series will last forever
Old Aug 1, 2007 | 09:01 AM
Default Re: (awdgsx96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">
It also didn't have an oil change in about 1.5 years, I just did that last week lol. : </TD></TR></TABLE>
I wouldnt really brag about not having an oil change, because that is something cheap that you can do that REALLY saves the life of the engine.
Old Aug 1, 2007 | 09:12 AM
Homesickelian's Avatar
Default Re: (professorman)
yeah, sersiously, with that kinda neglect don't brag about how old it is, cause it might not last much longer.
Mine is at 185,000 but my bro kinda neglected it for a while so I've had to put a good amount of money into it.
Worst is timing belt which you must do anyway, snapped CV axle which happened from a sucky previous driver probably, and a broken radiator which isnt bad lasting 185,000 miles.
The engine and transmission work great though. Transmission shifts smooth for a 5th gen accord and the engine burns 0 oil or coolant.
Old Aug 1, 2007 | 09:20 AM
BBallz24's Avatar
Default Re: (Homesickelian)
my 95 had 205K on it when I was T-Boned and it was totaled. It would still hit the 115 shutoff and had lots of life left in it. My 97 has 127K with 55K on the H22a. Routine maintenance will keep it running for a while. I've heard of people having 300K+ on their Hondas.
Old Aug 1, 2007 | 09:27 AM
JDM_Acccord's Avatar
Default Re: (BBallz24)
96 accord with 128,376.
Old Aug 1, 2007 | 10:05 AM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professorman &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldnt really brag about not having an oil change, because that is something cheap that you can do that REALLY saves the life of the engine. </TD></TR></TABLE>
I've only owned the car 1 month. This is coming from the previous owner
Old Aug 1, 2007 | 10:40 AM
IK_Noodle's Avatar
So far my 96 has 203,000 and I had to replace the engine at 196,000. I also replaced a bunch of other stuff like the radiator, wheel bearings, ball joints, the axles(3 times each), plus some other stuff but I drive the car pretty hard. I bought it with 84,000 on it about 4.5 years ago.
Old Aug 1, 2007 | 11:57 AM
thatasiankidtony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyard24 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I want to know about how long to expect my 97' to last. Just curious as to who has the most mileage on their own 5th gen. Accord.</TD></TR></TABLE>
I got my car (97 SE) last April with 150,xxx. Now it has 173,xxx. Still runs stong. Haven't done much other then replaced the mid pipe. and brakes.
Modified by thatasiankidtony at 1:12 PM 8/1/2007
Old Aug 1, 2007 | 12:01 PM
Slunk's Avatar
Default Re: 5th Generation Mileage?? (IK_Noodle)
My 97 lx has ~80k on it right now. I bought it with 30k in 04 and have only done the timing belt service and new tires.... If you stay on top of maintenance your should be able to drive it 250k plus.
Old Aug 1, 2007 | 12:30 PM
honda94accord's Avatar
Default Re: 5th Generation Mileage?? (Slunk)
94 EX with 153,XXX Still going strong. Did a carbon clean and replaced the plugs and wires and air filter when i bought it 8 months ago with 137,XXX. Just did the front brakes last weekend and the rear brakes are getting done this weekend. Still runs fine and everything. Got school for the next 2 years and hoping it will last me that long till i can get a new car. Im hoping to see it to 200,000+. Just gotta take care of them and they will last forever. I had a friend who had 403,XXX on his 93 civic before he totaled it.
Old Aug 5, 2007 | 01:34 PM
CBL9's Avatar
Default Re: 5th Generation Mileage?? (honda94accord)
1995 Accord EX V6 with leather. 98K miles we never drive it.
Old Aug 5, 2007 | 01:38 PM
361 accord's Avatar
oooh ooh pick me, my buddy in austin knows of a shop, has a loaner accord with over a million on the clock, all the do is regular stuff
oil change erry 3000
Old Aug 5, 2007 | 01:54 PM
TheMuffinMan's Avatar
He knows where you live!
195k on mine
Old Aug 5, 2007 | 03:54 PM
awdgsx96's Avatar
Default Re: (361 accord)
Do a search for the million mile Integra.
It looked like brand new from the factory.
And damn, what is your obsession with pissing on peoples lawns, and penises?
Old Aug 5, 2007 | 04:07 PM
361 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">Do a search for the million mile Integra.
And damn, what is your obsession with pissing on peoples lawns, and penises? </TD></TR></TABLE>
:edits sig:
lmfao!!!
Old Aug 5, 2007 | 08:08 PM
bowser_cd5's Avatar
my 95 ex got stuck a few years ago at 181,999
Old Aug 5, 2007 | 08:17 PM
dwayne1413's Avatar
Default Re: (bowser_cd5)
im sitting at 126k right now on my 1997 ex. bought it right about a year ago with 105k so i put alittle more then 20k in one year. thing runs great but i dont think it was taken care of as well as it should have been
