Ok, now WTF is the deal?
Old Jun 11, 2002 | 05:04 AM
TurboSedan's Avatar
New User
Default Ok, now WTF is the deal?
Please forgive me, this is so stupid. Weeks ago I found that I was sending coolant into the overflow tank while boosting and thus causing the car to overheat. I planned to change the head gasket. When the engine was running I could hardly squeeze the upper radiator hose with my hand enough to compress it at all. Now, not only have I boosted without displacing any coolant, but I can now compress the upper radiator hose with my hand easily with the engine running. I have not chnaged the head gasket! I tried, but I could not break the right upper mount bracket bolts free, so I had to put the stuff I took apart back together. That is all I have done. This is freaking me out now. Anyone have any ideas what it could be?
Old Jun 11, 2002 | 05:08 AM
CovertFI's Avatar
Default Re: Ok, now WTF is the deal? (97CivicFerio)
use a 2 foot breaker bar on the top engine mounts. now if you think that is hard, i can not remove the bolt holding the drive pully on with that breaker bar. so i have a car with 130k miles and the orginal timing belt! it sucks!!
good luck
Old Jun 11, 2002 | 05:15 AM
TurboSedan's Avatar
New User
Default Re: Ok, now WTF is the deal? (CovertFI)
I already tried a 3' breaker bar dude! My dad helped me and we could not budge those fawking things! Anyway, what could cause it to not send coolant into the overflow now when it was before? Thanks!
Old Jun 11, 2002 | 05:18 AM
T3EMSI's Avatar
get a little 10W40 and use a blow torch on it. It will losen up real quick, but make sure not to leave it on their long, if not you know what will happen.
Whenever I can't get something loose, straight to the garage for my torch!
Hope that helps
Later
Ricky
Old Jun 11, 2002 | 06:14 AM
echo999's Avatar
New User
Default Re: Ok, now WTF is the deal? (T3EMSI)
I couldn't get my drive axle nut off, so I drove it to some shop (in my case, Sears),
and had them use their air impact wrench.. they took it off in 3 seconds...
AND I was using a 5' breaker bar. (I'm guessing well over 250ft/lbs of force).
Those air impact wrenches can put out well over 1000ft/lbs of force if needed.
Old Jun 11, 2002 | 06:45 AM
92HB_HB's Avatar
Default Re: Ok, now WTF is the deal? (echo999)
IMPACT guns RULE supreme!! though some times i wish mine could provide more torque, say 600 ft/lbs... hehe...
Old Jun 11, 2002 | 06:55 AM
CovertFI's Avatar
i have an impact that puts out 250 and i cant break hardly anything. with a 5 footer i say you are putting out 700+ foot lbs for sure!!
Old Jun 11, 2002 | 07:50 AM
HXMan's Avatar
I would say a big breaker bar will put more torque out then any impact gun.
Old Jun 11, 2002 | 08:20 AM
dbman96's Avatar
New User
Default Re: Ok, now WTF is the deal? (HXMan)
Yeah but it's not just the torque, it's the fact that an impact gun provides that force in quick bursts... kinda like the difference between catching a .45 slug someone threw at you and catching it coming down the barrel of a gun.
Old Jun 11, 2002 | 09:49 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Ok, now WTF is the deal? (dbman96)
Very true, but it depends on the gun too. Both my 350ft/lb gun and my friend's 800ft/lb gun couldn't get my axle nut off. I used a ~2.5ft breaker bar (end of hydraulic jack) and it came off no problem. It was loud, when it broke, but it came off.
Old Jun 11, 2002 | 03:56 PM
Honda4CX-T's Avatar
Default Re: Ok, now WTF is the deal? (shamoo)
I know the feeling I have a 600ft/lb and a 1000ft/lb Impact wrench. I've taken off many axle nuts in my life in less than 6-seconds for both sides.
Now a friend brought his 1996 Escort into my garage to change his bad axles (common on most Escorts). He tried both guns without any luck. So I thought maybe this 'retard' does not know how to use tools ? Guess what that piece of S#*@ would not come off nor budge for me either.
Tried a 5" breaker bar with no luck. Finally put car back on flat floor lift, tried Impact Gun once more (600ft/lb) and actually snapped the freakin' axle !!! I was like WTF ???
Ended up grabbing the Air Cut-off tool & cut the axle nuts in half; I figured why fight with it if he's replacing them anyways. (Should of thought of that 2hrs ago )
[Modified by Honda4CX-R, 7:58 PM 6/11/2002]
Old Jun 11, 2002 | 07:48 PM
ion_four's Avatar
good luck
Sweet lord, man! You best get that **** off of there...the dealer only charges your first born...
Old Jun 11, 2002 | 09:15 PM
tonydatyga's Avatar
your cooling system is either running too much pressure (cap) or you need more water in your mixture b/c of the extra heat from FI. overflow is from heat expansion of the coolant. It should return to the radiator after cool down due to vacuum. Also bleeding out the air will sometimes fix an overflow problem. You may have done that inadvertantly whatever it is you did.
Old Jun 12, 2002 | 03:39 AM
Honda4CX-T's Avatar
Default Re: Ok, now WTF is the deal? (tonydatyga)
Dude, you sure you got the right topic here ? Check again >>>
Old Jun 12, 2002 | 04:32 AM
FBP Ex-T's Avatar
Default Re: Ok, now WTF is the deal? (Honda4CX-R)
i dont know too much about cooling systems...but i do know htis...its a honda..it fixes itself...i can vouch for that..
Old Jun 12, 2002 | 05:25 AM
CovertFI's Avatar
Default Re: Ok, now WTF is the deal? (ion_four)
the motor will be swaped out in about 2 months!!
Old Jun 16, 2002 | 07:56 PM
tonydatyga's Avatar
ahahah, sorry bout that. Mebbe it was the crack. Sorry do you feel better as a person now?
Old Jun 16, 2002 | 08:12 PM
PrecisionH23a's Avatar
it is def your head gasket, make sure to inspect your pistons too if you are yanking out your engine. you might wnat to have the head checked for warpage as well as the block. good luck
philkehn
30
Jun 17, 2010 02:39 AM
a97b18b
Mid-Atlantic
Apr 6, 2009 06:03 PM
nycpreludesh
Oct 4, 2008 09:32 AM
kysard
21
Aug 31, 2004 04:33 PM
