Need New Lug Nuts for new Rims??????
Im currently rolling on steelies, but will soon upgrade to spme aftermarket rims. Right now im thinking some rotas or MB motoring's. My question is will I need extended lug nuts???
Aftermarket rims have tapered lug holes. Stock rims have ball-type lug holes. You'll have to buy "tuner" lugs that have tapered ends.
Although you can probably roll on stock lug nuts like Doos, and it will probably be fine for awhile, it's incorrect and might cause damage to the rims.
EDIT - You only need extended lugs for use with extended wheel studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">Im currently rolling on steelies, but will soon upgrade to spme aftermarket rims. Right now im thinking some rotas or MB motoring's. My question is will I need extended lug nuts???</TD></TR></TABLE>
No. Not in most cases.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmai86 »</TD></TR><TR><TD CLASS="quote">EDIT - You only need extended lugs for use with extended wheel studs. </TD></TR></TABLE>
With extended wheel studs - which are often used with a wheel whose spoke design requires spacers to clear the brake calipers - open-end lug nuts are usually best, rather than extended lug nuts.
