question about how to take off a handle part
Old Jul 31, 2007 | 05:24 PM
datssoled's Avatar
Default question about how to take off a handle part
So im trying to take replace my front door handles with a set of keyless door handles but I am stuck at one part. How are you able to take the rod off for this step, with the pic as a reference. Here the guy suggests to use a flat head to take the c clip off, but I tried and it wont work. Are there any other ways to take the rod off?
pics were taken from here
http://forums.clubsi.com/ubbth...mport
Old Jul 31, 2007 | 05:37 PM
blanco617's Avatar
Default Re: question about how to take off a handle part (datssoled)
if your trying to take the bar on the bottom left of the picture off all you have to do is push the plastic piece down and it unclips then pull the bar out...
Old Jul 31, 2007 | 05:48 PM
Frosty_Sol's Avatar
Default Re: question about how to take off a handle part (blanco617)
What type of keyless system are you installing?
I put one in an EG that looked like this (taken from an Ebay auction, so sorry if it goes down, first pic i found):
Anyway, how the actuator works is, it moves a rod connected into your stock rod's location to act as the inner door lock. So, as the guy below posted, remove the rod from the plastic clip, mount in your actuator, and then cut the rod to the right length, and connect one end through the actuator and then the other through the same stock clip.
This has worked fine for me, and if this is the style keyless entry you are installing, then you do not have to take apart that assembly.
Old Jul 31, 2007 | 05:54 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blanco617 &raquo;</TD></TR><TR><TD CLASS="quote">if your trying to take the bar on the bottom left of the picture off all you have to do is push the plastic piece down and it unclips then pull the bar out...
x2.
The plastic clip rotates, then the rod can be removed, without having to remove the c-clip.
Old Jul 31, 2007 | 09:02 PM
datssoled's Avatar
in that way i can still replace the handle with a keyless one right?
Old Jul 31, 2007 | 09:39 PM
VRD^don's Avatar
that rod is a pain to remove..i had a hard time with it..carefull not to break anyother plastic pieces..!
Old Sep 22, 2007 | 04:58 PM
datssoled's Avatar
Default Re: question about how to take off a handle part (VRD^don)
i dont think you can take the plastic part off. I tried a few times already. It doesnt come off. Any other suggestions?
craiger02v6
Mar 26, 2015 04:45 PM
blackeg
Welding / Fabrication
13
Apr 24, 2010 04:20 PM
4drEF
13
Jan 13, 2004 08:18 AM
AussieK24
17
Jun 3, 2003 04:17 PM
