Sticky gas pedal issue
Old Jul 31, 2007 | 05:21 PM
Ganked's Avatar
Default Sticky gas pedal issue
Hey i was wondering if anyone could throw me some advice.. I noticed that my gas pedal is a bit sticky, if you try and press it lightly it wont move you have to slam your foot into it. I have already checked the cables in the engine bay and played around with those.. so any advice would be awesome.
Old Jul 31, 2007 | 05:23 PM
Daveys_pal's Avatar
Default Re: Sticky gas pedal issue (Ganked)
Come to think of it me too. Somebody jump in on this. I heard there was an issue with throttle cable on some Civics.
Old Jul 31, 2007 | 05:34 PM
94hondacivicvtec's Avatar
Default Re: Sticky gas pedal issue (Daveys_pal)
i had a problem with this when i first got my car, crap gets built up on the cable it self and it will stick open or crap builds up in the throttle body and it will stick bolth ways either close or open. best way to clean it is to take the throttle body off and clean it with carb cleaner and a rag or tooth brush.
Old Jul 31, 2007 | 05:38 PM
97Ej6mike's Avatar
It may be the spring for the throttle butterfly, it can get jammed sometimes. Some lube can fix that easy.
Old Aug 1, 2007 | 03:58 AM
Ganked's Avatar
Default Re: (97Ej6mike)
awesome will try the following out, and post back if it doesnt work
Old Aug 1, 2007 | 07:10 AM
rivaladore's Avatar
If its turns out to not be the cable then it could be your throttle body. so try this--------> take off your intake, spray some carb cleaner on your throttle body, scrub in there with an old tooth brush as you spray, wipe clean. Might be time to change your pcv valve.
Old Aug 1, 2007 | 09:55 AM
Relic1's Avatar
quick test to tell where the problem is... turn the throttle plate manually, if it's hard to move from the closed position then clean your throttle body.
If it moves free then replace your throttle cable.
My cable was kinked slightly right as it exits the firewall, caused it to stick only when it was closed.
Old Aug 1, 2007 | 05:12 PM
Ganked's Avatar
Default Re: (Relic1)
^ yeah the plate moves freely and good, so i guess it might be the cable? do you know how much they would go for.. I cant imagine it will be too expensive
Old Aug 1, 2007 | 05:13 PM
R Benefits's Avatar
Default Re: (Ganked)
Loosen the cable and then tighten it back up and see what happens.
Old Aug 2, 2007 | 03:42 AM
Ganked's Avatar
Default Re: (R Benefits)
loosened the bolt, re-tightned it... helped for about 5 mins then was back to normal
smc1118
May 5, 2014 04:55 AM
85crx509
Sep 3, 2008 11:10 AM
mr poo
15
Jun 14, 2006 08:09 PM
VtecBrian
Feb 20, 2006 06:01 AM
rasta420
15
Mar 15, 2003 05:38 AM
