CEL and wideband reading 10:1
well ok so i just got my 84mm ls vtec setup running and everything is great except once i start the car after about 5 seconds the check engine light pops on and my wide band hits 10:1 - 11:1 .... and also when i jumper the jumper wires the engine light just shuts off and never flashes... what could possibly be causing this?
any help would be much appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">what ems are you using?</TD></TR></TABLE>
no sir revs up just great! its really odd if i go to check the code the light simply shuts off... the car isnt throwing a solid cel being i can put the car on acc and i have no codes at all but after the car runs for 5 seconds or so the light pops on and my a\f's drop out at idle..
and also i had this same setup running fine in a different car previously so i know the ecu is fine!
Are both leds on the hondata unit green ?
If they are... Is your knock sensor enabled in your s300 calibration ?
If so, your ecu probably does not have a knock sensor...
Disable the knock sensor in the calibration & your problem will be solved.
If your still having problems, you really should consult with your hondata dealer.
Off topic but I am guessing you bought the hondata for some whored out price & contacted the dealer about the issue & received no response ?
If so, I have seen this happen several times on the board, you get what you pay for sometimes in product quality, customer service & technical knowledge.
yes u can and that is exactly what i did! i re-pinned a obd1 dizzy to obd2 plug and i double checked it the ckp is just bad! good ol dist king what a piece of ****!
ahobbs
Sep 12, 2003 08:41 AM
