can i use this clutch
Old Jul 31, 2007 | 03:45 PM
da6er's Avatar
Default can i use this clutch
i have a cable ls tranny with a clutch but im going to put a hydro tranny on the motor so can i use the clutch from the cable ls tranny?
thanx for the help
Old Jul 31, 2007 | 03:57 PM
fdavie's Avatar
Default Re: can i use this clutch (da6er)
Easy way to check this is to look up the part numbers for both and compare. Looks like they're the same p/n, so you probably can reuse it.
95 ls uses
clutch disk 22200-P72-015
pressure plate 22300-P54-010
92 ls uses
clutch disk 22200-P72-015 (same)
pressure plate 22300-P54-010 (same)
Old Jul 31, 2007 | 04:06 PM
da6er's Avatar
Default Re: can i use this clutch (fdavie)
thanx for the help man
DzKa
Jun 8, 2011 09:26 PM
Mindgamez
Transmission & Drivetrain
Feb 25, 2009 11:50 AM
Louis53123
Jul 23, 2006 11:16 AM
